JDM syncros VS. USDM syncros
Old Jan 7, 2006 | 11:50 PM
JUN-DA6's Avatar
Default JDM syncros VS. USDM syncros
Hi, is any one knows if JDM syncro rings for ITR tranny same as USDM ITR syncro rings?
thanks~
Old Jan 7, 2006 | 11:58 PM
revvin9k's Avatar
Default Re: JDM syncros VS. USDM syncros (JUN-DA6)
Old Jan 8, 2006 | 12:26 AM
Circuit Star-29's Avatar
Default Re: JDM syncros VS. USDM syncros (revvin9k)
The JDM units have little gerbals that install w/ the syncros. Something about adding to the WGP (Wheel Gerbal Power)... Unlucky little bastards....
Old Jan 8, 2006 | 08:34 AM
.Thomas's Avatar
Default Re: JDM syncros VS. USDM syncros (Circuit Star-29)
JDM units are bettaR!!
Old Jan 8, 2006 | 09:05 AM
seek167's Avatar
jdm units are carbon coated i think it only for 3,4 and 5 gear syncros . could be wrong on that
Old Jan 8, 2006 | 11:53 AM
Default Re: JDM syncros VS. USDM syncros (seek167)
THERE IS NO DIFFERENCE BETWEEN JDM & USDM SYNCROS!!!
Old Jan 8, 2006 | 10:21 PM
JUN-DA6's Avatar
Thank you star-29 you just answer my question. I am rebuilding my JDM ITR tranny so I just want to make sure USDM syncros will work with JDM gears.
Old Jan 8, 2006 | 11:44 PM
Default Re: (JUN-DA6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN-DA6 &raquo;</TD></TR><TR><TD CLASS="quote">Thank you star-29 you just answer my question. I am rebuilding my JDM ITR tranny so I just want to make sure USDM syncros will work with JDM gears.</TD></TR></TABLE>
If you are buying new syncros, go through http://www.Gear-speed.com They offer Carbon-Coated synros 3-5 for 150 shipped. Ask them for some of there scuffing paper and give the syncro-surface of the gear a quick, for the lack of a better term (at the moment ) "scuff."
I hope you have a manual or a person helping you...if this is your first time, you'll have a good time.
Old Jan 10, 2006 | 03:34 AM
JUN-DA6's Avatar
thank you, I have been looking for that web site. About the scuffing paper...is that important or just let the syncros brake in easier?
I have done replace gears...only problem I have is when putting the case back together, the snap ring on top doesn't like to go back too easy. Do you have any tricks to get the snap ring back in place easier? thanks
Old Jan 10, 2006 | 09:20 AM
HAHA...I hate that ring. There is a tool made for that specifc purpose. Thats the only trick I know. Or having a extra set of hand helps. Also, heating the case in the oven helps when you can't get the bearings in place.
As far as the "scuff" paper, Gear-speed uses it...so thats good enough for me
Old Jan 10, 2006 | 05:26 PM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN-DA6 &raquo;</TD></TR><TR><TD CLASS="quote">thank you, I have been looking for that web site. About the scuffing paper...is that important or just let the syncros brake in easier?
I have done replace gears...only problem I have is when putting the case back together, the snap ring on top doesn't like to go back too easy. Do you have any tricks to get the snap ring back in place easier? thanks</TD></TR></TABLE>
If you're having shifting problems, look at your synchro sleeves also..it's not always the ring that fails, but more the sleeve that slides over the gears/synchros...just a tip.
The case should go smoothly down until the snap ring hits the top of the countershaft bearing...then take out your snap ring pliers and the case should go down fine. If it doesn't, it's probably held up on the bearing, shift gate, or reverse idler gear or shift fork shafts...might lube them up before install. Make sure you test everything before hondbonding the case together to make sure all is good.
After you've torqued the case down, flip the tranny upside down to get the countershaft bearing to snap into the ring...works everytime.
Old Jan 10, 2006 | 07:58 PM
Default Re: (Evs-One)
Wise words from a pro...taught me all I know about trannies.
Old Jan 10, 2006 | 08:04 PM
iLOVEmyEMone's Avatar
Bump... i got no clue..
Old Jan 10, 2006 | 08:22 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">Wise words from a pro...taught me all I know about trannies. </TD></TR></TABLE>
no, you taugh yourself on a nasty raimy day, like tonight
Old Jan 10, 2006 | 10:25 PM
Oh, god...please do not remind me... then best thing evar was when you were like "Don't forget the release bearing when you put the tranny on..." And then Cres helps me lift the tranny into place, and joo were like "Did you remember the bearing?" DOH!!! ....Fitting I guess....
magicguy
Mar 6, 2010 12:53 PM
brxtacy
Sep 10, 2009 01:45 PM
scottishdave
Oct 19, 2005 02:02 PM
Nameless RB26
Mar 20, 2003 06:32 PM
