Engine swap 88 CRX Si
Old Jan 7, 2006 | 11:49 PM
schuey10101's Avatar
Default Engine swap 88 CRX Si
Will the engine that HMOTORSONLINE sells (30018 - 88-91 SOHC ZC longblock) be a direct swap in my 88, and will I be able to legally pass smog in California with this? If not what are my other options?
thanks
Old Jan 7, 2006 | 11:58 PM
payneth's Avatar
Default Re: Engine swap 88 CRX Si (schuey10101)
Yes, it will be a direct swap for you. Should be plug and play. And yes, i dont see why you wouldn't pass smog with it. Just make sure you have some extra cash to replace timing belt, HEad gasket, waterpump, and do a tuneup before you swap it into your car. It will def help out in the end, and keep your motor running longer!
Old Jan 8, 2006 | 12:19 AM
killa rex's Avatar
i don't know much about the ZC swap..but i think that it won't pass CA smog...my only suggestion is do a b16 or b18 and ref that thing
Old Jan 8, 2006 | 12:25 AM
So I guess my second question would be where could I get a D16A6 replacement then?
Old Jan 8, 2006 | 12:41 AM
89crx1184's Avatar
dont give up so easily... ask more around about zc engines..... i dont see why it wont pass CA smog... if ulll do a good tune-up change ur timing belt with water pump... then u shud be good.... on and put the highest fuel before u go so it would clean your whole fuel system... well thats my 2 cents
Old Jan 8, 2006 | 12:54 AM
payneth's Avatar
Default Re: (89crx1184)
like i said before, do what i posted above and you should be fine..
or you dont have to listen to me and your screwed
Old Jan 8, 2006 | 01:46 AM
Rbehne2's Avatar
How does your exhaust system look?? If the cat is rusted, you should probably replace it. But I wouldnt suggest anything high flow off the bat- just keep it stock to pass the test.
Old Jan 8, 2006 | 01:55 AM
Default Re: Engine swap 88 CRX Si (Rbehne2)
All stock and no rust is how I roll here in ella ayyyyy.
Old Jan 8, 2006 | 02:33 AM
Rbehne2's Avatar
you should be fine- continue your research on that setup. I was gonna go with that motor because i saw another rex owner with that motor beat a very lightly modded mk4 supra. have fun
Old Jan 8, 2006 | 09:50 AM
ghost_ryder35's Avatar
easy to pass, change your 02 sensor while your doing the tune up too!
Old Jan 8, 2006 | 10:34 AM
.Thomas's Avatar
its not the stuff coming out the tail pipe hes worried about, its all going to be clean and honda goodness. but the block stamping is an issue. because theres no sutch thing as an USDM ZC.
Old Jan 8, 2006 | 10:48 AM
TeamRedline89Hatch's Avatar
i dunno if it is any different, but my buddy legitamently passed his jdm d15b, he did a full tune up before the test and passed with ease.
Old Jan 8, 2006 | 11:51 AM
Rbehne2's Avatar
Do a search- some engine builders can re-stamp your block to say anything you want.
Old Jan 8, 2006 | 09:02 PM
killa rex's Avatar
the thing is that even if it passes the sniffer test...it won't pass the visual..CA laws are tough..i think we have the worst smog regulation there is..
CA Smog test
Emission, Function, and Visual....if u fail on any of these u won't pass
or u can try to get done illegally...but it will cost u and good luck finding someone that will do it...
Old Jan 8, 2006 | 09:12 PM
crxnj's Avatar
Default Re: Engine swap 88 CRX Si (xmunxjai648)
Yeah,it will pass the sniffer as long as the motor is running healthy and has correct ecu,But when the person sees "ZC" stamped on the block ::: FAIL..
You see all these swapped cars in cali going for so cheap and that's why..So unfortuneate
Old Jan 12, 2006 | 08:15 PM
killa rex's Avatar
man Cali smog laws are retarded..they can fail u just by looking in the engine bay. if they see a different color hose or not SAE approve hose...FAIL. even a sensor not plugged in...FAIL...damn visual test
mynameizstitch
20
Mar 5, 2008 07:13 AM
brandoom
62
Mar 20, 2007 01:15 AM
JCCOOL43
17
Oct 26, 2006 08:28 AM
drastikmeasurez
20
Feb 3, 2004 08:17 PM
IgniteTeg
Jun 4, 2002 04:06 PM
