Can GSR cams support 700 hp?
Old Jan 7, 2006 | 11:01 PM
TurboLaxx's Avatar
Default Can GSR cams support 700 hp?
I have a dart block and i'm about to get all forged internals. I bought a b16a3 head that was race ported and polished with beefy springs and aftermarket valves and retainers. This head came with gsr cams. I plan on boosting up to 30-35 psi for the track only. This will be a daily driver....no joke. I know the ITR cams are better because of the increased lift they provide, but the gsr cams should be nice for daily driving. Will the GSR cams work for around 700hp or do they crap out in the 500-600 hp range?? Other's dyno charts would be nice to see. Thanks.
Old Jan 7, 2006 | 11:19 PM
UncleD's Avatar
Default Re: Can GSR cams support 700 hp? (TurboLaxx)
Here are CTR cams at 35 psi on c16. GT4067 with a 87x83...
Sleeved B16 (81.5) with CTR cams, t3/67 on 93 octane @ 15 psi..
84 custom built motor, stroke?? GT40R - .85 housing, CTR cams...C16@38 PSI..
Modified by clean rice at 10:53 AM 1/9/2006
Old Jan 7, 2006 | 11:42 PM
B00STFREAKS's Avatar
Default Re: Can GSR cams support 700 hp? (clean rice)
If i am correct Cortney Green made 801whp on GSR cams
Link proving so.
Old Jan 8, 2006 | 01:12 AM
The Tea-father's Avatar
Default Re: Can GSR cams support 700 hp? (B00STFREAK)
Buck and jasen both of them making over 800hp with GSR cams
Old Jan 8, 2006 | 04:47 AM
thermal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00STFREAK &raquo;</TD></TR><TR><TD CLASS="quote">
Link proving so.</TD></TR></TABLE>
wow!!!!!!!!!!!
Old Jan 8, 2006 | 04:51 AM
91civicDXdude's Avatar
not trying to rain on anyones parade, but if you're looking to make 800hp, dont you think that some properly designed aftermarket cams would help out alot more than the 'OEM cam bandwagon' ? i mean, sure, it can be done on stock cams, but maybe its a lot easier and thers more power to be made with a bigger aftermarket cam?
it seems to me the comparison would be like building a 12:1 compression small block with a bad *** intake and carb and then using an 'rv cam'
Old Jan 8, 2006 | 06:31 AM
HR-1320's Avatar
Default Re: (91civicDXdude)
We made 817hp on b16 cams @ 9000rpm. But that was on methenol at 40lbs of boost.
Old Jan 8, 2006 | 06:43 AM
t4EK9's Avatar
i will be runung gsr cams with a AEBS sleved b18c1 and a GT71mm Q trim PT turbo and motec and we will be makeing over 700
Old Jan 8, 2006 | 08:05 AM
Turbo-charged's Avatar
Default Re: (t4EK9)
why does power start dropping off at 7500 rpm on that bottom graph?
Old Jan 8, 2006 | 08:12 AM
boosted94cx's Avatar
* B A N N E D *
if you've got the money to build the setup....why not spend a little more for some bigger cams?
Old Jan 8, 2006 | 09:34 AM
TurboLaxx's Avatar
why would i need bigger cams if the GSR cams will work just fine as people have shown me?
Old Jan 8, 2006 | 09:48 AM
LostSolVTEC's Avatar
Default Re: (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">why does power start dropping off at 7500 rpm on that bottom graph?</TD></TR></TABLE>
shot turbo, and was losing boost
Old Jan 8, 2006 | 10:16 AM
turbotime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">not trying to rain on anyones parade, but if you're looking to make 800hp, dont you think that some properly designed aftermarket cams would help out alot more than the 'OEM cam bandwagon' ? i mean, sure, it can be done on stock cams, but maybe its a lot easier and thers more power to be made with a bigger aftermarket cam?
it seems to me the comparison would be like building a 12:1 compression small block with a bad *** intake and carb and then using an 'rv cam'</TD></TR></TABLE>
it would be a better idea. But aftermarket cams are hit or miss. Some a regrinds, some are just poorly made. I have seen skunk2 and crowler cams snap in half, while OE quality remains tried and true. Not to say OE cams wont break, but i have seen less examples of them breaking than I have seen of aftermarket cams breaking.
And As you make know, broken cams do not make for a happy valvetrain.
Personally I plan on running the CTR or ITR cams in the GSR head this summer
Old Jan 8, 2006 | 10:32 AM
93H22ACX's Avatar
Default Re: (turbotime)
we've made 740whp on gsr cams... t3/67 ho here's one of the dyno...
Old Jan 8, 2006 | 11:16 AM
* B A N N E D *
Default Re: (TurboLaxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLaxx &raquo;</TD></TR><TR><TD CLASS="quote">why would i need bigger cams if the GSR cams will work just fine as people have shown me?</TD></TR></TABLE>
easy...more power for the same setup. same power with less boost
why NOT get bigger cams...if you have the means to do so?
Old Jan 8, 2006 | 11:54 AM
tokesGTR's Avatar
Default Re: (s13-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s13-t &raquo;</TD></TR><TR><TD CLASS="quote">
why NOT get bigger cams...if you have the means to do so?</TD></TR></TABLE>
Exactly.
You arn't giving up any amount of streetability if you move to ITR/CTR or even some slightly bigger aftermarket cams vs. GSR's, so your "but the gsr cams should be nice for daily driving" comment doesn't hold any water. Jeff Evans posted a comparison on his site between B16 and GSR cams, the GSR cams made much more low end and mid range power, and spooled the turbo quicker. I could imagine the same would happen moving to ITR cams over GSR cams, so in that case why would you sacrifice any mid range power by not running the slightly larger cams? Especially if you think this is going to be a daily driver.
Old Jan 8, 2006 | 01:16 PM
1fastvtec's Avatar
Pertaining to the subject of OEM cams, how well do the stock H22 cams or the Type-S cams perform? I am in the same boat when I get my H22 and build it. I like certain OEM products, and the cams are one of them?
weak_sauce
Aug 18, 2012 10:06 AM
staindgd
Jan 28, 2008 06:28 PM
Hatchorama
Oct 31, 2005 05:00 AM
yanasaki
Aug 5, 2003 11:31 PM
