99-00 Civic Si Eibach 26mm Front Sway fit 1994 Del Sol Vtec???
Old Jan 7, 2006 | 10:59 PM
Lex2Go's Avatar
Default 99-00 Civic Si Eibach 26mm Front Sway fit 1994 Del Sol Vtec???
Someone is selling a 99-00 Civic Si front sway bar 26mm. My question is will this fit the 1994 Del Sol Vtec with stock 24mm sway bar. Thanks for the answer in advance.
I've already searched and nothing out of search help me answer my question.
Old Jan 7, 2006 | 11:21 PM
Lex2Go's Avatar
Default Re: 99-00 Civic Si Eibach 26mm Front Sway fit 1994 Del Sol Vtec??? (Lex2Go)
Bump
Old Jan 8, 2006 | 01:32 AM
alwaysoverkill's Avatar
should fit but why would you want to go from 24 to 26mm, this will increase understeer even more.
I believe civic 92-00 front sway bars are the same. Meaning Del Sol and Acura 1.6EL are both included in this since they are based on the civic. someone else will verfiy though
Old Jan 8, 2006 | 07:02 AM
6SPD_EK's Avatar
Default Re: (alwaysoverkill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alwaysoverkill &raquo;</TD></TR><TR><TD CLASS="quote">
I believe civic 92-00 front sway bars are the same. Meaning Del Sol and Acura 1.6EL are both included in this since they are based on the civic. someone else will verfiy though</TD></TR></TABLE>
wrong front sways are different
92-95 civics & 94-01 tegs & del sol's are interchangeable
96-00 civic's are different (front suspension is different/non interchangeable)
if it was possible I would hope you have a 22+mm rear sway to complement it...a LSD would help to eliminate gobs of understeer too
Old Jan 8, 2006 | 08:37 AM
Lex2Go's Avatar
Default Re: (adirondackR)
Thanks for the answer guys. I think I'll just stick with the stock 24mm sway bar and just replace the bushing that's all wore out.
POE
22
Apr 4, 2019 08:25 AM
targa del sol
Apr 2, 2010 05:37 PM
321POOF
Mar 3, 2008 09:40 AM
topher
Apr 5, 2002 06:28 AM
97ITR
Oct 16, 2001 09:06 PM
