My vacuum at idle for 8:5:1 compression
Old Jan 7, 2006 | 10:17 PM
1epmugenlude's Avatar
Default My vacuum at idle for 8:5:1 compression
I was wondering if 12psi sounded normal for an engine with 8:5:1 compression that would be 12psi at idle.?? Any inputs would be appreciated.
Old Jan 7, 2006 | 10:31 PM
Default Re: My vacuum at idle for 8:5:1 compression (1epmugenlude)
please help
Old Jan 7, 2006 | 11:16 PM
im seeing -.72 bar or 530 mmhg at idle with this h22 of mine.. sound ok ?
Old Jan 8, 2006 | 01:19 AM
abnaasefmb's Avatar
Default Re: (1epmugenlude)
if your hitting 12psi @ idle you must have a very fast spooling turbo
Old Jan 8, 2006 | 01:23 AM
oops, ...I meant negative 12 on my profec e01..
Modified by 1epmugenlude at 3:27 AM 1/8/2006
Old Jan 8, 2006 | 02:27 AM
abnaasefmb's Avatar
12 seems kinda weak i pull 20 @ idle but thats a stock b16
Old Jan 8, 2006 | 05:05 AM
Frozen E's Avatar
H-T White Ops
shouldn't really matter what kind of compression you're running. vacuum should stay damn near the same compared to a stock motor. So yeah, around 20" should be right. You may have a slight leak somewhere.
Old Jan 8, 2006 | 05:47 PM
boosted k20's Avatar
Default Re: (IslandSi)
check the timing belt to make sure the cam gears r lined up
abmerop18
Jun 10, 2006 05:04 PM
KeyserSoze
Oct 20, 2005 08:36 PM
DeeJay
Oct 3, 2002 03:52 PM
b00stedbyFastrax
Sep 15, 2002 06:54 PM
