Euro-R Cams, Should I put it on?
Old Jan 7, 2006 | 09:27 PM
K-Spec's Avatar
Default Euro-R Cams, Should I put it on?
I have a set of brand new Euro-R cams sitting around and was wondering if it would even be worth it to put it in when all I have are the simple bolt-ons and a stock engine (no head work w/ stock internals)? Let me know what you guys think.
Old Jan 8, 2006 | 09:18 AM
K-Spec's Avatar
Default Re: Euro-R Cams, Should I put it on? (khalal538)
any ideas?
Old Jan 8, 2006 | 11:29 AM
InvaderTrax's Avatar
...yes
Old Jan 8, 2006 | 12:53 PM
Missing Gears's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">I have a set of brand new Euro-R cams sitting around and was wondering if it would even be worth it to put it in when all I have are the simple bolt-ons and a stock engine (no head work w/ stock internals)? Let me know what you guys think.
yes, it would be worth running those cams.
they should be the same as type s cams, you can run those w/ stock valvetrain and depending on tunning, you should pick up about 5hp or so up top.
Old Jan 8, 2006 | 03:09 PM
fastfu's Avatar
Default Re: Euro-R Cams, Should I put it on? (Missing Gears)
i don't get it
you tell him thats its worth it and then say he'll only get 5hp and thats with tuning
Old Jan 8, 2006 | 03:37 PM
K-Spec's Avatar
Default Re: Euro-R Cams, Should I put it on? (fastfu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastfu &raquo;</TD></TR><TR><TD CLASS="quote">i don't get it
you tell him thats its worth it and then say he'll only get 5hp and thats with tuning </TD></TR></TABLE>
so...no, don't put it on?
Old Jan 8, 2006 | 03:46 PM
fastfu's Avatar
i thought you would get more than 5hp imho
be if your happy with 5hp then do it
Old Jan 8, 2006 | 05:57 PM
what do you expect from oem cams? may get a couple more than that, depends on setup and tunning, every motors different.
Old Jan 8, 2006 | 06:30 PM
K-Spec's Avatar
so do you recommend any type of cam gears to go with these and how hard is it to install cams? Do you need any special tools?
Old Jan 8, 2006 | 06:42 PM
you can run stock camgears, but if you have never installed cams before i would recommend having someone experienced give you a hand. dont forget to adjust your valves.
Old Jan 8, 2006 | 06:59 PM
K-Spec's Avatar
would it help to get those aftermarket adjustable cam gears and if so, which one do you recommend? thnx for your help btw.
Old Jan 8, 2006 | 08:14 PM
you can move the power around w/ cam gears, may be able to get a little more out of them. i like crower cam gears, they use 12 pt arp bolts, new design easy to read, and affordable. i would rather put my money towards an intake manifold or ex. manifold, would get more out of that.
Old Jan 8, 2006 | 09:15 PM
mgags7's Avatar
hes already got the cams though....i think it would be a good mod....you will feel some more grunt so i say yes....why not anyways....its not like its that hard to do....
Old Jan 9, 2006 | 06:27 AM
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">hes already got the cams though....i think it would be a good mod....you will feel some more grunt so i say yes....why not anyways....its not like its that hard to do....</TD></TR></TABLE>
i never gained anything adjusting gears w/ those cams, but like i said every motors different. i personaly would rather put money towards an intake manifold if i was on a budget, you would gain alot more from an intake mani.
Old Jan 9, 2006 | 09:25 AM
FOdoFAsho's Avatar
Default Re: (Missing Gears)
i hear the intake manifolds do alot for those motors...id go with that also....
Old Jan 9, 2006 | 10:20 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears &raquo;</TD></TR><TR><TD CLASS="quote">i never gained anything adjusting gears w/ those cams, but like i said every motors different. i personaly would rather put money towards an intake manifold if i was on a budget, you would gain alot more from an intake mani. </TD></TR></TABLE>
yeah, but people seem to forget about things like that....they will have $4000 worth of cams and pistons and all on a "modified" stock manifold....that thing just doesnt cut it....
Old Jan 9, 2006 | 12:16 PM
soundbomber's Avatar
it's all about itb's y0
HONDA?
Feb 7, 2015 06:38 PM
type_r_teggy
Aug 22, 2008 09:52 AM
megalomaniac001
Honda S2000
10
Mar 14, 2008 01:13 PM
slowsleeper
Sep 14, 2004 06:08 PM
Slipknt777
Jul 27, 2004 11:07 AM
