ZC help
just instaled a ZC in my other CRX. Its an 88 SI and i'm having trouble with the vacuum lines from the MAP sensor and the 2 small black canisters located next to it. I've tried to look at other swaps but they all seem to be in 89 - 91 CRX/Civics where there's only one small canister next to the MAP.
Anyone got a up-close pic of an 88 with a ZC swap? Or even a diagram which shows the location of these lines?
I know they all go to the TB, but there's less spots on the ZC TB to put them.
any help is appreciated.
mike
mike
...I have a zc in mi 88Si and I can tell you that one of the vacuum lines I just tapped-offed....I can get pics to show you exactly, but what two black canisters are you talking about....and is one of them the fuel filter?
later
...tried to e-mail you but was sent back (undeliverable)
crxagogo
later
crxagogo
o.k i don`t have pic`s but i will try here ...o.k their should be a red line from the cabister that goes to the one on the top (should be only one place it fits) of the troddle body. the other is from the map and it should go more to the front of the troddle body then there is one more thats next to the map.. plug it .. i don`t know if this will make sense but **** i tryed.. good luck
DesiDez
Jun 24, 2003 08:41 AM
