clutch upgrade to 5G civic
Old Jan 7, 2006 | 09:13 PM
shadycrx's Avatar
Default clutch upgrade to 5G civic
Just wanted to be sure, to upgrade to the 92-95 civic clutch/pressure plate you just bolt on a 92-95 flywheel and use your EF transmission, CORRECT? are the sizes 220mm (EG) and 212mm (EF) ?
Old Jan 7, 2006 | 09:49 PM
dr_latino999's Avatar
Default Re: clutch upgrade to 5G civic (shadycrx)
You use your stock transmission as long as it is not an 88 (Different Spline Count)
Old Jan 7, 2006 | 11:12 PM
31flavorscivic's Avatar
Default Re: clutch upgrade to 5G civic (dr_latino999)
The clutch and flywheel from 90 through 00 is the same. 212mm I believe. 89 has 200 MM, and 88 has 21 spline transmission and 200mm clutch.
CivicxTree754
15
Jan 29, 2011 04:51 PM
highrev1987
Feb 15, 2006 06:57 PM
teamrushhatch
Oct 15, 2003 11:23 AM
mugensport9
10
Sep 23, 2003 09:01 PM
