will OEM mounts work for b series
Old Jan 7, 2006 | 06:27 PM
Beau Gotti's Avatar
Default will OEM mounts work for b series
will OEM mounts bolt up for a b series swap? i might be getting a nice b16 for hella low for my 91 CRX.
mainly worried about hood clearence, but i can get a JDM replica CF hood, or zc hood for pretty cheap
Old Jan 7, 2006 | 06:30 PM
C1CRX's Avatar
Traffic signal tech
Default Re: will OEM mounts work for b series (Beau Gotti)
are you talking about the OEM crx mounts or OEM b16 mounts?
Old Jan 7, 2006 | 06:32 PM
Beau Gotti's Avatar
Default Re: will OEM mounts work for b series (lvcrx)
OEM b16
Old Jan 7, 2006 | 06:38 PM
kulangot's Avatar
you can, but you have to do alot of re-welding..
Old Jan 7, 2006 | 08:11 PM
DRAMA's Avatar
reweld frame mounts or use a mount kit
Old Jan 7, 2006 | 08:33 PM
rewerbcrx's Avatar
Default Re: will OEM mounts work for b series (StReEt TuNeR)
CUSTOM MOUNT KITS!!! hasport.com, jdmshit.com, passwordjdm. com i believe has one... and there are others... just look.. its worth the time and money to buy them instead of cutting and welding...
Old Jan 7, 2006 | 09:52 PM
dr_latino999's Avatar
Default Re: will OEM mounts work for b series (rewerbcrx)
But if cutting and welding is your thing, go right ahead. If you have available a SiR front clip you can definetly take measurements from that, I don't know so much about a DA though.
bayFERIOroan
Suspension & Brakes
13
Dec 16, 2013 10:50 AM
steronz
Jun 6, 2013 07:15 PM
SpoonREVS
May 23, 2012 12:11 PM
acmoc
11
Dec 7, 2008 04:07 PM
JohnnieChimpo
31
Dec 15, 2004 03:36 PM
