how to remove the seal on the hub for b16 swap
Old Jan 7, 2006 | 05:56 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default how do you remove the seal on the hub for b16 swap
what the title says
thanks in advance
Old Jan 7, 2006 | 06:07 PM
CRXBart's Avatar
Default Re: how do you remove the seal on the hub for b16 swap (turbob16EF)
Put a screw driver behind it and pry it up. I can't beleive there is a thread about this, but I suppose I will help anyway, I'm just going to whine about it.
Old Jan 7, 2006 | 06:11 PM
turbob16ef's Avatar
Default Re: how do you remove the seal on the hub for b16 swap (CRXBart)
thanks, i was just making sure before i mess something else up.
Old Jan 7, 2006 | 06:42 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbob16EF &raquo;</TD></TR><TR><TD CLASS="quote">thanks, i was just making sure before i mess something else up. </TD></TR></TABLE>
No problem here to help.
Old Jan 7, 2006 | 11:55 PM
civic889802's Avatar
SCREW DRIVER N HAMER ARE UR BEST FRIEND S W40 SPRAY IT FIRST
RACEPAK
11
Mar 23, 2007 01:50 PM
nexgen91
Jan 25, 2007 12:30 PM
RICKYritethere
Jan 24, 2007 10:57 AM
Nameless Warrior
Dec 1, 2006 04:55 PM
CaliforniaHighwayPatrol
18
Sep 9, 2005 10:44 AM
