DPFI to MPFI, NO Spark, D16a6
Old Jan 7, 2006 | 04:54 PM
91' LS-VTEC's Avatar
Default DPFI to MPFI, NO Spark, D16a6
90' DX, D16A6,
This is a freinds car I'm trying to get running. He picked up the car after some one did the swap, but befor they got a chance to do the wiring.
Using : http://www.geocities.com/teampimports/fuelinj.html & http://www.angelfire.com/d20/h....html
I got spark once. After that the motor just cranks. For a wile I didn't get any codes. Then I started switching coils (1 at a time) and ignitors, but still no spark. I also held my dizzy out of my B16 in place and cranked it to see if I would at least get a spark,but nothing.
I went threw today and checked all the wires and wiring. Looks like 2 of the wires might have been wrong, or it could of been from all the trys. Nevertheless, I got a CODE 15. So I went threw and tried another Ignitor, and it eleminated the code, but the car still won't start.
Heres a pic that I was using aswell, to make shure my wires are correct. ::
I'm out of ideas. Any help is apriciated.
Old Jan 7, 2006 | 05:08 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: DPFI to MPFI, NO Spark, D16a6 (91' LS-VTEC)
This is another view of the harness realize this view is holding it upside down:
Your wire colors may slightly vary due to age and discolorization..
Have you tried switching the two white ones?
This is a drawing of the distributor plug/wires viewed normally:
Old Jan 7, 2006 | 05:19 PM
Default Re: DPFI to MPFI, NO Spark, D16a6 (88DXCRX)
I've tried switching them. I'll go in and switch them. Then try a diffrent coil see what happends. then go threw switch them back try a driffrent ignitor. Switch them again try another peice. Now I've ran out of day light, and have to recharge my battery.
Thanks for postin gthe better pics. Alot easier to read in those.
Old Jan 7, 2006 | 09:03 PM
civic889802's Avatar
check ur ecu i had teh same problem but then later found out was my ecu but now i got a b16 but yeah ecu could be the problem n mine use to crank but no spark
Old Jan 7, 2006 | 09:19 PM
aaronhume's Avatar
Default Re: (civic889802)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic889802 &raquo;</TD></TR><TR><TD CLASS="quote">check ur ecu i had teh same problem but then later found out was my ecu but now i got a b16 but yeah ecu could be the problem n mine use to crank but no spark</TD></TR></TABLE>
same here, check the pins on the ecu plugs, I messed mine up with the dpfi to mpfi conversion, and had toget some new wire ends to put in the plugs.
Old Jan 8, 2006 | 12:47 AM
YUP ECU WIRING ALWAYS DOUBLE CHECK DOES UR ECU TROW ANY CONES OR DOES IT TURN ON DOES UR FUEL PUMP RUN
Old Jan 8, 2006 | 03:12 AM
STREETWERKZ's Avatar
i would also say ECU.
i had this problem with B16 into a DX.
well, actually...... AFTER it was broken into.
i took the ECU out, and when my 'great friend' reinstalled the ECU, he accidently bolted a wire underneath the ECU and pinched it until it cut open and shorted.
needless to say, it didnt fire.
after i got it to fire, we had another problem with an injector dumping WAAAAAAY too much fuel.... (also, shorted wire)
after the two fixes. it ran PERFECTLY ever since.
Old Jan 8, 2006 | 08:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic889802 &raquo;</TD></TR><TR><TD CLASS="quote">YUP ECU WIRING ALWAYS DOUBLE CHECK DOES UR ECU TROW ANY CONES OR DOES IT TURN ON DOES UR FUEL PUMP RUN</TD></TR></TABLE>
Fuel pump is good. I got fuel threw the fuelrail.
ECU was throwing a code15,replaced the ignitor and the code went away.
As soon as it warms up a little I'll be outside trying the ECU.
Will trying my PR3 ECU work? As far as just getting it to start up. I know the fuel maps are diffrent.
Old Jan 8, 2006 | 09:27 AM
mycrx7's Avatar
Default Re: (91' LS-VTEC)
ya itl run and drive just as the pm6 but you'll the cel light will be on.
Old Jan 8, 2006 | 04:09 PM
Default Re: (mycrx7)
OK...tripple checked the wiring.
Using my B16 Dizzy and my PR3 ECU..we got spark. Switched ECU's and still have spark.Car sounds better, still hasn't turned over, but its starting to putter.
Little bits of backfire, but its almost there.
Now after I crank it I'll get a cell. Code 8. TDC Position crank angle sencor.
So close now.
Old Jan 8, 2006 | 09:14 PM
Alright. After trying the PR3 ECU & dizzy. We went in and gutted my dizzy and put it all into the D16 dizzy (coil,ignitor,rotor,everything). We went outside to test it,and NOTHING&gt; Back to square 1. NO SPARK!
Old Jan 12, 2006 | 10:20 AM
aaronhume's Avatar
when you did wiring at the ecu did you depin any of the wires such as the ones that go to TDC at the dizzy? when i did my swap I had perfect continuity from ecu plug to dizzy, but the problem was not the wires, it was the pins themselves that got messed up during depinning. just try using some good ones from a junkyard plug or something... you may be surprised.
Old Jan 12, 2006 | 07:14 PM
Default Re: (aaronhume)
well I'll recheck the ECU pinouts.
If anyone can post pics of there ecu/pin outs, I would appreciate it. Just want to make shure I did it rite. I'm almost ready to give up on this car.
Old Jan 12, 2006 | 08:25 PM
onePOINTsix's Avatar
check the thermostat ground? IDK
JCRXTURBO20916
Oct 13, 2009 06:06 AM
spikehead221
Jun 13, 2009 12:44 PM
mattcivic
Oct 9, 2007 06:06 AM
Hella_Fresh
19
Mar 31, 2007 12:35 AM
importboi22
11
Jun 22, 2004 01:10 PM
