Best PROVEN motor oil for a JDM B16a
Old Mar 19, 2002 | 09:59 PM
CHRIS 1.8's Avatar
Default Best PROVEN motor oil for a JDM B16a
I heard Mobil 1 10W-30 is good?
Old Mar 19, 2002 | 10:06 PM
RexB16's Avatar
Default Re: Best PROVEN motor oil for a JDM B16a (only JDM)
i use mobil one for this simple reason
its the oil that ferrari and porche puts in their cars. plus its always good to minimize friction as much as possible on a motor that revs like a b16 can.
Old Mar 19, 2002 | 10:09 PM
CHRIS 1.8's Avatar
Default Re: Best PROVEN motor oil for a JDM B16a (RexB16)
Which Mobil 1? 10W-30 or 10W-40?
Old Mar 19, 2002 | 10:13 PM
RexB16's Avatar
i dunno what weight. but i use 5-30
Old Mar 19, 2002 | 10:15 PM
CHRIS 1.8's Avatar
What's the difference?
Old Mar 19, 2002 | 10:21 PM
RexB16's Avatar
lower you go in number the thinner the oil is.
Old Mar 19, 2002 | 10:23 PM
CHRIS 1.8's Avatar
So 10W-30 is best?
Old Mar 19, 2002 | 10:24 PM
RexB16's Avatar
i dunno that it makes that much of a difference, but ur owners manual says 5-30
Old Mar 19, 2002 | 10:25 PM
CHRIS 1.8's Avatar
Ok cause I have a B16 also.
Old Mar 19, 2002 | 10:26 PM
chhuong's Avatar
There are quite a few good motor oil company's. But mobil 1 is not a real synthetic, it is a mineral based synthetic and not a true synthetic oil, but is still good. But the theory goes is that you can move up to a full true synthetic but you can't move down. So from that i'll name some of the top company's out there: Royal Purple, Redline, Amsoil, NEO, Oil Xtreme. Those all have been proven to be better than mobil 1 or any oil you can get at a regular store like target, wal-mart etc. As for me, ever since i got the motor up and running i've only used mobil 1, but just recently switched to a full true synthetic and i noticed that it smoothed the revs, and quieted my car at idle. HTH
Old Mar 19, 2002 | 10:29 PM
CHRIS 1.8's Avatar
Default Re: Best PROVEN motor oil for a JDM B16a (chhuong)
What full true synthetic oil do you use?
Old Mar 19, 2002 | 10:30 PM
RexB16's Avatar
he's rightm full synthetic and will not mix with conventional oils.
RexB16's Avatar
dont, unless u want to be stuck using that at every oil change.
Old Mar 20, 2002 | 12:26 AM
DCx2xNV's Avatar
if yall really knew **** about oil ... mobil 1 is good but REDLiNE is bettah
Old Mar 20, 2002 | 07:48 AM
CHRIS 1.8's Avatar
I'm using Mobil one right now so if I get Royal Purple, Redline, Amsoil, NEO, or Oil Xtreme, I can just use it from there? Do they carry those at your local auto parts store?
Old Mar 20, 2002 | 07:52 AM
civteg1's Avatar
mobil 1 is not a real synthetic, it's mineral based so therefore not a true synthetic oil, I usd to use it but then I switched to royal purpal 5w/30 and I love it I use it in JDM ZC and in my JDM b18c I have read reviews about different synthetic oils and royal purpal was rated the best even better then red line. I didn't break down like the rest
[Modified by civteg1, 4:53 PM 3/20/2002]
[Modified by civteg1, 4:55 PM 3/20/2002]
[Modified by civteg1, 4:56 PM 3/20/2002]
Old Mar 20, 2002 | 08:03 AM
E-AT_me's Avatar
Default Re: Best PROVEN motor oil for a JDM B16a (civteg1)
i've heard amsoil is better.
but would it be ok to use synthetic in a used, 40 thousand mile B16a from japan?
Old Mar 20, 2002 | 08:14 AM
crxgurlllll's Avatar
I used mobil 1 in my ZC and after about 1000 miles it started seeping at the gaskets... I went back to conventional and im all sealed up again...
Not a good idea to use synthetic on high mileage engines that have run on conventional their whole life
Old Mar 20, 2002 | 09:40 AM
chhuong's Avatar
Default Re: Best PROVEN motor oil for a JDM B16a (eraser)
Yeah if your motor is still pretty low on miles like under 50k i say you can do the switch. But remember you can switch around with different full synthetics but you can't move down to like a mobil 1 anymore!! RIght now i've been using royal purple 5 30 and i'm loving it, but now im going to try amsoil, cuz i too have heard it's better. So i'll let everyone know if they are in about 2-3 weeks.
Old Mar 20, 2002 | 09:47 AM
Jesse H's Avatar
It's so annoyingly nice to hear people say
"oh this is better, oh that's better, I heard this, I heard that" without any supporting facts. Do a search, I'm certain there's a link to a good resource somewhere in the archives.
Old Mar 20, 2002 | 12:15 PM
Malgerus's Avatar
Royal Purple all the way!!!! Stuck some 5w30 in my bro's JDM B16 and it ran smoootthhh (with more power as well!) it's expensive, but worth the $
Old Mar 20, 2002 | 12:35 PM
CRX-RX's Avatar
Default Re: Best PROVEN motor oil for a JDM B16a (89_Y_49)
Anyone use Motul??? I'm using Mobil 1 right now, and for a daily driven car you can't go wrong.
Old Mar 20, 2002 | 04:45 PM
big pete's Avatar
Default Re: Best PROVEN motor oil for a JDM B16a (CRX-RX)
no!! crisco is the best!!
Old Mar 20, 2002 | 05:23 PM
StorminMatt's Avatar
Mobil 1 is indeed a full synthetic. All it could otherwise be is a synthetic blend or a conventional oil. As far as being made from mineral oil, all oils are whether synthetic or not. Basically, synthetic oils are made by polymerizing (basically just 'assembling') small molecules like ethylene into larger ones. And ethylene (and other such feedstock chemicals) is just a byproduct of petroleum refining.
[Modified by StorminMatt, 2:23 AM 3/21/2002]
Old Mar 20, 2002 | 05:30 PM
akachef's Avatar
New User
Default Re: Best PROVEN motor oil for a JDM B16a (big pete)
leading edge oil.
contact jeff at importbuilders.com
