questions about a 86 accord
Old Jan 7, 2006 | 03:00 PM
johnzm's Avatar
Default questions about a 86 accord
hey guys heared this acord is carberuated. needed to know what motors BOLT in AND the trans bolts up.
it overheated, and i know that if we can do a manifold swap on a newer motor it might be easier. will any of the newer motors bolt up and accept the card'd manifold so that we can keep it simple?
Old Jan 7, 2006 | 03:04 PM
hondadude's Avatar
Default Re: questions about a 86 accord (johnzm)
86-89 are all the same engine and your best way to go as far as having a running car again soon and cheap
Old Jan 8, 2006 | 06:25 AM
Honda-Master's Avatar
put a low miles japanese engine in it,they come with 40-45k miles ,,it is a long block all you do is swap manifolds, alt, compress etc etc
Old Jan 8, 2006 | 02:28 PM
ericw's Avatar
A20, BS, and BT are all the blocks that bolt in. There are no other motors that bolt in except the ACCORD B20a from japan, but you will need the transmission with it. I wouldn't bother with getting a A20 block from japan since they are so abundant here and can roll 300,000 miles with no problem as long as they are taken care of.
Old Jan 8, 2006 | 05:29 PM
civic_90_08's Avatar
Default Re: questions about a 86 accord (ericw)
Any (86-89) motor will go in it...fuel injected or carbed...may need a lil work, but they will... For the motors from Japan that will go in Cars like this and Mine is the B20Z i think... I know that it uses the stock mounts and tranny...its just a matter of finding one and gettin it in your car
The JDM B20 is a DOHC motor
Jasontrammell
Apr 27, 2018 12:36 PM
darvin
Jan 3, 2008 11:07 AM
accordmaui
Jan 28, 2003 03:40 PM
MugenGTR
Feb 18, 2002 07:18 AM
