High pressure in Valve cover?
Old Jan 7, 2006 | 01:18 PM
92vteclude's Avatar
Default High pressure in Valve cover?
I just went to add some oil to my engine with it running and when i took the cap off alot of pressure keeps coming out. Call me dumb, but I had a jeep and when I did this, I didnt have this kind of pressure. I am guessing it must be a honda thing, the car runs fine. It must be just the pistons going up and down and the drainback holes in the head letting the moving air up into the head.... Correct me if I am wrong... I didnt think is would be this much. The engine burns very little oil 1/2 way on the dipstick at 3000mi. and it doesnt lose coolant.
~Joe~
Old Jan 7, 2006 | 01:25 PM
Sabbotage's Avatar
Default Re: High pressure in Valve cover? (92vteclude)
why would you put oil in your car when its running? Shut it off and then add oil.
Old Jan 7, 2006 | 03:27 PM
BlueLude94's Avatar
Default Re: High pressure in Valve cover? (Sabbotage)
There shouldn't be pressure, vacume if anything. Check your spark plugs, make sure they are tight.
Old Jan 7, 2006 | 04:53 PM
vinuneuro's Avatar
Default Re: High pressure in Valve cover? (BlueLude94)
There should be pressure....there is a valve cover breather to relieve pressure.
Old Jan 7, 2006 | 06:47 PM
Hawkze_2.3's Avatar
Default Re: High pressure in Valve cover? (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote"> There should be pressure....there is a valve cover breather to relieve pressure.</TD></TR></TABLE>
Yep, that and a PCV valve to suck out the pressure. Technically air is supposed to come into the breather and out the PCV...
Old Jan 8, 2006 | 10:48 AM
92vteclude's Avatar
Thanks for the responses, The search function worked now... I guess it is normal.
~Joe~
Old Jan 9, 2006 | 07:39 AM
NoVALude's Avatar
Default Re: High pressure in Valve cover? (Hawkze_2.3)
do you have a breather filter on the back of your cyl. head cover? trying to determine what to do for that?....
Old Jan 9, 2006 | 09:29 AM
1GPlusSH's Avatar
Default Re:
<A HREF="https://honda-tech.com/zerothread?id=697498
" TARGET="_blank">https://honda-tech.com/zerothread?id=697498
</A>
http://64.233.161.104/search?q...rt=25
Very long read but worth it
Old Jan 9, 2006 | 09:42 AM
92vteclude's Avatar
Yes i have a breather connected to my valve cover, going to my cai
Looneytunerz
Nov 2, 2012 12:57 PM
Mr.Chow
27
Jan 6, 2012 06:29 PM
crxb16sir
17
Dec 16, 2009 12:27 AM
ITR092
Feb 10, 2006 05:27 PM
