17 inch volks offset +50 anygood for itr???????
Old Jan 7, 2006 | 01:03 PM
19inchbitch's Avatar
Default 17 inch volks offset +50 anygood for itr???????
I just both 17 inch volks racing ce28 with 215/40/17 potenza tires with an offset of +50.Do you guys think it gonna rub or fit the car?
Old Jan 7, 2006 | 01:05 PM
Ed 341's Avatar
Default Re: 17 inch volks offset +50 anygood for itr??????? (19inchbitch)
Let us know when you put them on
Old Jan 8, 2006 | 06:51 AM
Default Re: 17 inch volks offset +50 anygood for itr??????? (Ed 341)
i can't put them on cause my car is in storage for winter.
Old Jan 8, 2006 | 07:50 AM
nsxtasy's Avatar
H-T Order of Merit
Might rub, might not. You'll have a better chance to avoid rubbing by getting 205/40-17. 205/40 is also exactly the same outer diameter as the stock tires, so there will be no change in speedometer or odometer accuracy.
In my experience, you have a significant chance of rubbing any time you increase the tread width by 20 mm or more AND choose a tire with a larger outer diameter. Just do one or the other (like with the 205/40-17) without going crazy, and you're unlikely to rub.
Old Jan 8, 2006 | 09:30 AM
BRICKHEAD's Avatar
Default Re: 17 inch volks offset +50 anygood for itr??????? (nsxtasy)
I have seen people run DC5 ITR wheels on their R's and they fit fine. I have a set for my rsx and I have to run a 5mm spacer in the back. The tires are the stock rsx size also wich if im not mistaken are 215-45-17. Hope this helps.
Civic138
Jun 6, 2007 04:37 PM
bigbadboss101
Apr 23, 2006 09:27 AM
yellow_ek
Dec 3, 2005 04:38 PM
JDubya
Sep 3, 2003 09:49 PM
Toda Party
Jul 3, 2001 10:40 PM
