Shifter Sticky
Hey, I just bought an 89 CRX Si, and the shifter is pretty stiff. Is there anything I could do to loosen it up so so that it wasn't as difficult to change gears? Thanks a lot. (Sorry, I'm not too car savvy)
just go ahead and drain the old tranny fluid out and then fill it with it with 2 quarts of10x30 motor oil. if problem persists, could be a few diff things. does the car shift correctly, as in pulling the cars momentum.
Mine was like that when I got it too. First off change the tranny fluid, it's easy and since you don't know how long it's been in there, you should do it anyway. Mine had heavy gear oil in it (the manual calls for 10W-30). Next take apart the linkage under the boot, it's pretty straightforward. Clean it, grease it, and reassemble it. If you overtighten the bolt that holds the shift rod to the shifter, it will be hard to move because the bushing is binding. Make it as tight as you can while maintaining good shifter feel, this is easiest with someone under the car adjusting it and someone inside playing with it.
it could just be that the bolts on the shifter base and/or on the transmission are torqued down way too hard.
Loosen those up and then make them finger tight and check your shifter feel again.
Adjust from there. Make sure to use a lock nut on the shifter base, though.
B18c5__Owns
Apr 3, 2006 10:28 PM
