D15 Series Motor Won't Start
Old Jan 7, 2006 | 11:41 AM
super_mut's Avatar
Default D15 Series Motor Won't Start
No feedback from the motor. Tried to manually crank the motor and it is very easy to turn over. Did I lose compression on the motor? Battery is ok. When I try to crank the motor it doesn't even crank. What happened? I think we lost compression.
Old Jan 7, 2006 | 11:45 AM
Coltmorris's Avatar
Default Re: D15 Series Motor Won't Start (super_mut)
so your battery is ok but when you turn the key it doesnt crank? Maybe bad starter? Did you check all your grounds? Check your main relay soldering? Fuses?
Old Jan 7, 2006 | 04:52 PM
PAStA MAAAN's Avatar
Default Re: D15 Series Motor Won't Start (Coltmorris)
anyone... ?
Old Jan 10, 2006 | 11:09 AM
Default Re: D15 Series Motor Won't Start (PAStA MAAAN)
*bump*
Integra_Boi
Jul 31, 2003 08:13 PM
GSRaCeRbOI
Aug 31, 2002 08:14 AM
hmonglonertim
Apr 26, 2002 02:12 PM
jared3
10
Apr 9, 2002 11:38 PM
