B16 crank removal
I am waiting for my hlems in the mail and I need to take the crank out of my b16 so i can get it to my machine shop, and i was wondering if you could possibly tell me the proper dis-assembly pattern for removing the crank from my block. any help would be great thanks
Just like the cams only go backwards. Start at the upper right, lower left, upper left, lower right, and work your way in going 1/4 turn at a time.
Should work out just fine for you.
you can look at my assembly pictures and go backwards if that helps
http://www.doublejz.com/enginewriteup.html
For the below picture start at 10 and go backwards
