Painting questions...
Old Mar 19, 2002 | 09:15 PM
Cryptopsy's Avatar
Default Painting questions...
I am getting my wings west kit painted soonish. I know of a cheap shop that did my old thunderbird for cheap.
My question is, what sorts of things should I be asking the paintshop before they paint my body kit?
In general, how many layers of paint will I need (stock tahaitian green)?
Also, how many layers of regular clear coat?
What about paint and clear coat additives? I heard that I should ask about flex agents, is there any other additives that I need to make sure is being used?
If you guys know of any other things I should double-check with the shop before I send the kit over, please post them up. I want a good paint job, not a shitty one, so I need to ask the right questions. Thanks!
Old Mar 20, 2002 | 04:19 AM
Cryptopsy's Avatar
Default Re: Painting questions... (SoulflyCRXsi)
ttt please. thank you
Old Mar 20, 2002 | 07:06 AM
CIVIX's Avatar
If you want a good paint job it's not going to be cheap. Some shops that I know can paint a kit for a good price something like $150 but you supply the materials. What they also do is only give you one layer of paint which isn't much at all you need maybe two or three layers depending if you are changing to another color or not. The real thing you should look into is getting a good base coat like Dupont or PPG but the most important thing is the clear coat. Spend a good amount of money for a good clear coat like Dupont. It is kind of expensive but the outcome is worth it. Oh and about two layers of clear will do just fine. I used to paint cars for a shop called Kruzzin Klassics
Old Mar 20, 2002 | 07:39 AM
Cryptopsy's Avatar
Default Re: Painting questions... (CIVIX)
Ok, I am actually not changing colors, BUT my body kit that is getting the paint is primed grey. How many layers of paint will I need? Three?
Old Mar 20, 2002 | 08:22 AM
CIVIX's Avatar
Yes you could use three coats which would be best because it's your front bumper and it may get knicked with rocks etc. so three layers will protect it better than just one!
Old Mar 20, 2002 | 09:44 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If you have to tell the shop how to paint it to have them do it correctly, I'd go to another shop.
Old Mar 20, 2002 | 09:49 AM
blackDA's Avatar
Default Re: Painting questions... (PatrickGSR94)
don't paint it without flex agent. it will cause your paint to spiderweb on curved edges.
Old Mar 20, 2002 | 03:40 PM
Cryptopsy's Avatar
Ya man, good point...
GoLowDrew
Paint and Body
Jun 23, 2013 10:22 AM
ank009
Paint and Body
Mar 8, 2012 12:23 PM
twinloop
Dec 30, 2006 10:19 PM
Blade121
Apr 29, 2006 01:37 PM
DanielLaruso
Sep 22, 2003 11:36 AM
