4 wire o2 sensor (searched)
Old Jan 7, 2006 | 09:14 AM
Coltmorris's Avatar
Default 4 wire o2 sensor (searched)
My car is converted to obd1 i have a d16a in it...car is already wired to run a 4 wire o2 sensor i just need to plug it in..except..there are more than 4 wires im seeing here..My 12v source is from the battery, I have 4 wires coming from the harness (purple, orange, black, grey) And I have another white wire coming from the harness..im very confused here...any help appreciated thanks!
Old Jan 7, 2006 | 09:58 AM
K20EF8's Avatar
Default Re: 4 wire o2 sensor (Coltmorris)
the 4 wires are grey signal, yellow 12v+, brown heater, and purple is ground
the white is for a Knock if you had it
Old Jan 7, 2006 | 10:02 AM
Coltmorris's Avatar
wow it is dark brown..your amazing haha..thanks alot man that saved me!
Old Jan 7, 2006 | 10:21 AM
Coltmorris's Avatar
ok so..problem 2..i wired up the sensor and started it up and my cel didnt go away...so i probed the splices with a voltmeter and there was no voltage on any..so i followed to the pruple yellow grey and brown wires to my ecu..and they seem to be hooked up fine..but no voltage from them..BTW..when i jump my ecu to get my engine codes the cel does not blink..this means i have a bad chip right? could this be the reason for my wires being dead?
Old Jan 7, 2006 | 11:42 AM
Coltmorris's Avatar
anyone?
sh!ft
Jul 23, 2009 01:07 PM
92B20VTEC
Apr 24, 2009 12:59 PM
400WHPITR
Feb 10, 2007 08:17 AM
bmiller17
10
Mar 17, 2006 09:54 AM
W0oT
Jul 10, 2002 08:11 PM
