Rota Slips - What width/offset to get?
Old Jan 7, 2006 | 09:03 AM
bluebullet's Avatar
Default Rota Slips - What width/offset to get?
I want Rota Slipstreams for my 99 si, which ones would be better and what is the recommended tire size. Thanks in advance.
15 x 7.0 +35
-or-
15 x 6.5 +40
Old Jan 7, 2006 | 10:37 AM
SpoolnEG6's Avatar
Default Re: Rota Slips - What width/offset to get? (bluebullet)
i'd probably go with the 15x6.5 et40's and use a 195/55/15 on them.
Old Jan 7, 2006 | 11:27 AM
bluebullet's Avatar
Default Re: Rota Slips - What width/offset to get? (SpoolnEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnEG6 &raquo;</TD></TR><TR><TD CLASS="quote">i'd probably go with the 15x6.5 et40's and use a 195/55/15 on them. </TD></TR></TABLE>
Thanks, but can you give me a reason why? I'm not challenging you, I'm just not too familiar with wheel/tire stuff.
Old Jan 7, 2006 | 11:51 AM
SpoolnEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebullet &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks, but can you give me a reason why? I'm not challenging you, I'm just not too familiar with wheel/tire stuff.</TD></TR></TABLE>
I recommended that because with the 15x7 et35 will come out towards the fenders more, I'm not 100% but they may come out a little too far and if your lowered you may get some rubbing on the car.
Old Jan 8, 2006 | 01:23 PM
DRFlickner's Avatar
For the Honda, the Slipstreams come in 15x7 w/ a +40mm offset, or 15x6.5 w/ a +40mm offset.
Usually, if you don't plan on tracking the car/driving it hard, the 15x6.5's will be adequate. If you feel like you need that extra half inch of width on your track/you want to run wider tires, then the 7" width is for you.
The 15x7's also cost slightly more than the 15x6.5's (something else to consider, although it's almost a negligible amount).
Old Jan 8, 2006 | 11:19 PM
bluebullet's Avatar
Default Re: Rota Slips - What width/offset to get? (DRFlickner)
I would rather run a tire closer to a 205 / 50 / 15
the Rota website says the 7" are 35mm offset and the 6.5" are 40mm
Fat Chick Magnet
Jun 22, 2006 07:33 AM
typer710
Jan 31, 2005 09:53 PM
Nothing.Special
10
Apr 5, 2004 09:11 PM
Hybrid
Apr 12, 2003 01:12 PM
