SI Front Sway Bar HELP!!!
I am new here and a friend told me there were alot of users on this site that were very knowledgable when it comes to honda's so here is the question I need answered. Will a 99 Civic SI front sway bar work/fit a 96 4dr civic DX. I know I might have to weld a bracket or something to connect the end links but not sure if the size/bends are right for my civic. Any help would be GREATLY appreciated. Thanks in advance...
Modified by smellerd at 11:05 PM 1/7/2006
Yes it will fit just fine. No need for welding though. You will need to get the lower control arms from the Si however. Yours doesn't have the holes for the endlinks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">I believe you also need the front shock forks which I have for sale if you need.
t3h shameless plug
</TD></TR></TABLE>t3h shameless plug
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">Yes it will fit just fine. No need for welding though. You will need to get the lower control arms from the Si however. Yours doesn't have the holes for the endlinks.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">I believe you also need the front shock forks which I have for sale if you need. </TD></TR></TABLE>
correct...although I did this swap & the forks look the same
but I believe they are different. lol, so get 'em from EL Vap133
...don't forget the 99-00 si endlinks & the "d' brackets that go on the busings
I bought the energy suspension bushings too
I hope you have a good rear swaybar set up to complement a big front sway...having a LSD will help to
pinoyboy204
Feb 24, 2008 03:56 PM
Bullitt
Aug 7, 2006 07:58 AM
