Timing belt install question
Old Jan 6, 2006 | 07:50 PM
dpkelly's Avatar
Default Timing belt install question
When putting the tension on the timing belt by rotating the crankshaft counterclockwise so the camshaft moves 3 teeth, must the spark plugs be installed while this is happening???
Old Jan 6, 2006 | 08:10 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Timing belt install question (dpkelly)
they can be or not it is up to you. the engine spins easier with out then being in. i usually do it with them in.
Old Jan 6, 2006 | 08:14 PM
.Ry's Avatar
.Ry
Default Re: Timing belt install question (boostedcivicsir)
Doesnt matter, if they are out of the engine the air in the combustion chamber has somewhere to go, making it easier to turn over.
jtwoj1
Jun 5, 2015 08:24 PM
blackep925
Jan 23, 2008 03:26 PM
civicdelsol33
Dec 19, 2007 08:44 AM
