What ECU to use with this swap?
If you did a '93 b18a1 swap into a 91 civic i was told you change the distributor and ecu to run obd0 in an obd0 car.
I changed the distributor and i also got a pr4 ecu...the car is turning over and won't start...do i need a pg6 ecu which is from the 89ish integras, is that obd0?
And does that make pr4 obd1, or wtf?
Maddox
10
Apr 11, 2004 11:24 AM
