What fuse blew?
Old Jan 6, 2006 | 03:05 PM
monalisa overdrive's Avatar
Default What fuse blew?
Hey everyone, just a quick question:
I was installing a new head unit in my car, and i think the battery line grounded out, because now my clock is gone, my trip odometers reset every time i start the car, and the stereo doesn't turn on. I looked around the fuse boxes but i dont know which one is the culprit. anybody know? Thanks in advance.
Old Jan 7, 2006 | 03:00 AM
Default Re: What fuse blew? (monalisa overdrive)
ttt
Old Jan 7, 2006 | 07:02 AM
The Weather Man's Avatar
You just have something hooked up wrong.
The trip odometers will reset if they are not grounded - so will the clock and the radio preset stations - you need to ground those.
If a fuse blew - they would never work because there would be an open in the circuit.
Old Jan 7, 2006 | 03:34 PM
Default Re: (TheKINGPin)
i dont see what's wrong though cause the radio isnt hooked up, and the clock doesnt even show up. when i try to hook up the radio, it won't turn on. isn't there a fuse related to that somewhere?
Old Jan 7, 2006 | 03:53 PM
SteveoBA8's Avatar
Default Re: (monalisa overdrive)
clock/radio(ecu) fuse in the engine compartment fuse panel
Old Jan 7, 2006 | 04:49 PM
BB6racer's Avatar
check the under-hood fuse box for a bog 100 amp fuse, these tend to blow when you ground the battery. it's not like the normal blade-type fuses though, there are 2 screws holding it down, and it has a clear top so you can actually check if its blown without removing it. thats happened to me when i grounded the alternator with a wrench while replacing the belt.
Old Jan 8, 2006 | 10:11 AM
SteveoBA8's Avatar
Default Re: (BB6racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer &raquo;</TD></TR><TR><TD CLASS="quote">check the under-hood fuse box for a bog 100 amp fuse, these tend to blow when you ground the battery. it's not like the normal blade-type fuses though, there are 2 screws holding it down, and it has a clear top so you can actually check if its blown without removing it. thats happened to me when i grounded the alternator with a wrench while replacing the belt.</TD></TR></TABLE> I did the exact same thing. lucky i had one from my front clip i used.
thomaswjparker
Mar 24, 2014 06:59 AM
Mishima
Jun 30, 2009 09:08 PM
Sic_DA_Nine
Audio / Security / Video
Jan 7, 2007 11:04 AM
TheAutoboxer
Apr 13, 2003 10:40 PM
2LoW4FaThOeS
Aug 4, 2002 10:40 PM
