1990 Honda Accord Shakes like crazy at idle..
2 Things, my car shakes pretty intenstly when its at idle, i noticed that it pretty much stops when i put it in neutral, but if its in gear it shakes alot
Spark Plugs, wires, cap/rotor, all new,
The sparkplug tube seals are leaking so i have oil on my plugs.. could that be it?
someone suggested i take off the throttle body and adjust it and clean it
i have the same problem, i have a 91 accord lx. Were you able to solve the problem? I am about to her for a major tune up. What are the parts that i need to replace? It has 165k mileage. Can you provide a list for the complete list when performing a major tune up? Thanks
look at that rear mount, at first it looks ok, but if you look closer you see it bouncin like it had hydrolics on it. mine is same way. 40 dollar part at advance, im gonna change mine first day off work
Major Tune-up;
Part: / Suggested Manufacturer
Spark Plugs (4) (NGK)
Spark plug Wire Set (1) (Honda)
Distributor Cap (Honda)
Distributor Rotor (Honda)
Pcv Valve
Air Filter
Fuel Filter
Can / Bottle Injector Cleaner
bad Vibration?: My wifes '89 Accord Auto needed the Rear Transmission Mount.
P
Pcv Valve
Air Filter
Fuel Filter
P
Trunkzdbz
May 17, 2014 12:21 AM
