EDM Cluster
Old Jan 6, 2006 | 11:44 AM
SD_Lurker's Avatar
HT White Ops
Default EDM Cluster
Does anyone have a link or write up on how to install the EDM 1.6v crx cluster into the USDM civic. YES I searched.
Old Jan 6, 2006 | 12:03 PM
SD_Lurker's Avatar
HT White Ops
Default Re: EDM Cluster (nicks_jdmstyle_ef9)
bump any help appreciated. thanks guys
Old Jan 6, 2006 | 12:17 PM
Pee Wee's Avatar
ill try and find the print out i used
Old Jan 6, 2006 | 12:22 PM
Pee Wee's Avatar
Default Re: EDM Cluster (EF8opey)
http://www.angelfire.com/ca/DrOhm/SiRcluster.html
Old Jan 6, 2006 | 12:27 PM
SD_Lurker's Avatar
HT White Ops
we tryed to use this one but my brother said that its wrong. Maybe because he was in such a rush that he missed something. We are gonna try it again tonight. Did you have any issues with this write up?
Old Jan 6, 2006 | 12:49 PM
Pee Wee's Avatar
is it an 88-89 or a 90-91
Old Jan 6, 2006 | 12:54 PM
CRX Toad's Avatar
I hope Ace$nyper is taking notes on this. All we ever hear about is his danged EDM cluster.
Old Jan 6, 2006 | 12:56 PM
SD_Lurker's Avatar
HT White Ops
90-91
Old Jan 6, 2006 | 01:09 PM
Pee Wee's Avatar
anyone with a 90-91 used the link for the install?
Old Jan 6, 2006 | 01:28 PM
highrev1987's Avatar
i tried it but he has some of the wires labeled wrong the ones for the tach i think are incorrect. if youre using the 1990 sir cluster it should plug up fine did you try that w/o wiring?
Old Jan 6, 2006 | 01:37 PM
Johnny G's Avatar
Hi,
You have a UKDM vtec cluster if its the one you bought from me:
http://cgi.ebay.com/ebaymotors...02259
Here is the link on how to install it, I found it in the FAQ section!
Hope this helps
Thanks
Modified by Johnny G at 2:50 PM 1/6/2006
Old Jan 6, 2006 | 01:51 PM
SD_Lurker's Avatar
HT White Ops
Default Re: EDM Cluster (Johnny G)
pmed
Old Jan 6, 2006 | 01:56 PM
SD_Lurker's Avatar
HT White Ops
that link is not right. the wires do not match up the same. unless something is wrong with the cluster. we matched up everything and it still wont work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrev1987 &raquo;</TD></TR><TR><TD CLASS="quote">i tried it but he has some of the wires labeled wrong the ones for the tach i think are incorrect. if youre using the 1990 sir cluster it should plug up fine did you try that w/o wiring?</TD></TR></TABLE>
ya its the 90-91 crx cluster
SD_Lurker's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">we tryed to use this one but my brother said that its wrong. Maybe because he was in such a rush that he missed something. We are gonna try it again tonight. Did you have any issues with this write up?</TD></TR></TABLE>
so you are saying that its plug and play? I have not tryed that yet
Old Jan 6, 2006 | 01:58 PM
Pee Wee's Avatar
i still think you have to repin some wires
Old Jan 6, 2006 | 01:59 PM
SD_Lurker's Avatar
HT White Ops
ya it cant be just plug and play. we are gonna figure it out one way or another. i hope that nothing is wrong with the cluster. Johnny gave me a good deal on it and he seems like a cool guy so I am sure if anything is wrong he will stand by his parts.
Old Jan 6, 2006 | 04:35 PM
EFSiR's Avatar
Hey, that's my link and it's right.
Old Jan 6, 2006 | 04:42 PM
Deetz's Avatar
Crazy Honda Guy
I'm using one in my 91 model. It is plug and play.
Only 2 wires have to be switched.
Old Jan 6, 2006 | 04:50 PM
Pee Wee's Avatar
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">I'm using one in my 91 model. It is plug and play.
thats not plug and play j/k
Old Jan 6, 2006 | 05:02 PM
EFSiR's Avatar
Default Re: (Deetz)
This does not seem to be the case with the cluster I got, which is exactly the same as the UK cluster.(mine is in km/h) In my cluster, I had to rewire all the wires. IT's all documented on my site.
Mine works exactly as how it's described above...[B]BUT THE BIG THING IS THAT THIS IS FOR THE CIVIC.
/B]
JapJunkie's Avatar
Post pics once installed...I think I want that cluster
Old Jan 6, 2006 | 05:45 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (EFSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSiR &raquo;</TD></TR><TR><TD CLASS="quote">
/B]</TD></TR></TABLE>
Here's a pic of mine in km's, i didn't change a damn thing, didn't even switch the 2 wires for the engine and parking brake dummy bulbs.
Old Jan 6, 2006 | 05:56 PM
SD_Lurker's Avatar
HT White Ops
Default Re: (Deetz)
there is no way that thing is plug and play. What do you have civic or crx?? what year and model?? That is wierd why would yours be plug and play but everyone else had to wire theres? I have the UKDM cluster from a 90-91 crx but that shoudl not matter because it should also work in a civic
Old Jan 6, 2006 | 06:12 PM
Deetz's Avatar
Crazy Honda Guy
^^ I have a 1991 Honda CRX SI made in Japan, which was sold in the Canadian market.
I also have a couple Civic which use the exact same connections as the 2 CRX's i also own, which makes the cluster esy to switch from one car to another with the correct mounting parts.
Old Jan 6, 2006 | 06:14 PM
silentdork818's Avatar
Default Re: (nicks_jdmstyle_ef9)
All the udkm clusters ive gotten never worked because of different pin-outs so i just swapped the ukdm parts (speedometer, tach face, ect) into the old USDM clusters. If you do this you have to use the same kind of cluster, Nippon Denso clusters are different than Nippon Seiki clusters.
