Passenger side power lock not working
Old Jan 6, 2006 | 10:59 AM
_Bug_'s Avatar
Default Passenger side power lock not working
I just bought an 96 EX Coupe (actually from a H-T member). The power lock on the passenger side isnt working, but the driver side works just fine. Could the fuse be bad if the driver side is wtill working? If not what would I need to fix to get it working? Any info would help, thanks!
Old Jan 6, 2006 | 12:06 PM
TurboEKcoupe's Avatar
Default Re: Passenger side power lock not working (JDM_Bug)
the metal bar that connects to the hinge is prolly off...start from there
Old Jan 6, 2006 | 06:14 PM
_Bug_'s Avatar
Default Re: Passenger side power lock not working (TurboEKcoupe)
I'll try that, but if were off wouldnt I be able to feel something moving inside the door from the outside?
Old Jan 7, 2006 | 10:08 PM
CB7VTEC's Avatar
probably the actuator, they kind of suck *** as they age on older ek's. take the door panel off (easy) and give it some power to see if the problem is in the wiring or in the actuator. worst case scenario, you have the hook up at honda
Old Jan 7, 2006 | 10:09 PM
_Bug_'s Avatar
Old Jan 7, 2006 | 10:14 PM
khme12's Avatar
Remove the door panel, press the power lock button and see if anything is working right in there.
Old Jan 7, 2006 | 10:31 PM
CB7VTEC's Avatar
bug, bring it to me and i'll fix it
Accord9422
Mar 5, 2012 05:08 PM
rcm
Sep 23, 2008 07:35 PM
bonta-kun
Oct 10, 2006 03:14 PM
GapxGuy
Jul 27, 2006 08:41 PM
