Any bolt on rear sway bars for hf's?
Old Jan 6, 2006 | 10:15 AM
HT Chaplain's Avatar
Loved
Default Any bolt on rear sway bars for hf's?
I heard you can only get rear sway bars for si's is this true? i have a 89 hf what is everyone using?
Old Jan 6, 2006 | 10:22 AM
Tyson's Avatar
Default Re: Any bolt on rear sway bars for hf's? (HT Chaplin)
only Si have rear swaybars. non si cars dont have the threaded holes to even mount the stock brackets. you can make some modications to make it work however.
suspension techniques uses their own brackets. so it doesnt matter which car you have. just get that.
Old Jan 6, 2006 | 10:37 AM
EJ1 wilcox's Avatar
Default Re: Any bolt on rear sway bars for hf's? (Tyson)
I have an STD hatch that didn't come with front OR rear sway bars.
The suspension techniques rear bar bolted right up. It uses a brackets that mount in existing locations.
I also added a front sway bar from a 93 integra that bolted right up too. I just had to buy ES endlinks and new mounting brackets.
Old Jan 6, 2006 | 10:43 AM
Tyson's Avatar
Default Re: Any bolt on rear sway bars for hf's? (EJ1 wilcox)
HF's already have front swaybars. but theirs are smaller, lighter because theyre hollow. theyre actually more sought after to some ppl because of the lower spring rate.
Old Jan 6, 2006 | 10:45 AM
Loved
thanks guys
Old Jan 6, 2006 | 11:15 AM
DocSean's Avatar
If you wanted to use and Si swaybar you would just need Si rear lower contol arms. I have both, you can have them if you pay for shipping.
But then again, it proably wouldn't be cheap to ship that stupid swaybar.
Old Jan 6, 2006 | 11:18 AM
Tyson's Avatar
Default Re: (spankjelly)
youd still need a way to bolt the bracket to the chassis.
with ST kit, neither the SI arms or factory mounting holes to the chassis are needed.
Old Jan 6, 2006 | 11:20 AM
DocSean's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">youd still need a way to bolt the bracket to the chassis.
with ST kit, neither the SI arms or factory mounting holes to the chassis are needed.</TD></TR></TABLE>
By golly you are right, nevermind.
rupensane
Dec 1, 2008 07:00 PM
vadersi
Dec 8, 2004 08:03 AM
jdmstreethatch
Nov 11, 2004 12:20 PM
viprcr1
Aug 16, 2003 04:58 PM
Civic44
Jul 8, 2002 06:15 AM
