b18a coverting to obd1
Old Jan 6, 2006 | 09:16 AM
rewerbcrx's Avatar
Default b18a coverting to obd1
i need
distributor
92-95 ecu :: what is the ecu name?
harness
if i convert over to obd1 then can i get rid of the map sensor and maybe the control box? and all that crap
Old Jan 6, 2006 | 09:34 AM
rewerbcrx's Avatar
Default Re: b18a coverting to obd1 (rewerbcrx)
bump
Old Jan 6, 2006 | 10:04 AM
Rywire's Avatar
use your cars harness, obd1 dizzy, obd1 ecu from a b18b/a , 4 wire o2, and whatever wiring jumpers you feel you need.
we have all these parts on our sire, fyi
Old Jan 6, 2006 | 10:35 AM
rewerbcrx's Avatar
Default Re: b18a coverting to obd1 (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">use your cars harness, obd1 dizzy, obd1 ecu from a b18b/a , 4 wire o2, and whatever wiring jumpers you feel you need.
we have all these parts on our sire, fyi </TD></TR></TABLE>
do i need a different distributor with your harness? or does the jumper resovle that... also do i need to change my injectors with your harness? i most likely will go with your system becuase i heard good things if i was to buy your harnes and distribitor jumper harness what else would i need to get? ... i don't know the difference between buying those on your site and buying this
88-91 CRX/Civic Si/Hf/Ex to b18a (OBD1 LS) for 165
Old Jan 6, 2006 | 10:59 PM
Rywire's Avatar
The 165 is the subharness for the 4 wire o2 as well.... The parts you need as far as wiring is a ecu jumper, and if you are not 100% on the dizzy, get the dizzy jumper too!
And yes, you NEED a obd1 dizzy, the obd0 dizzy is different internally
Ryan
Novtecdohc
Aug 18, 2005 06:32 PM
alexsracing
Nov 14, 2004 01:37 PM
Mefain
Feb 16, 2004 09:39 PM
wickedEFguy
Feb 11, 2003 03:01 PM
7rrivera7
Nov 9, 2002 06:38 AM
