ls crx stalling help
I have a 90 crx si with b18a1 obd0
The last couple days its been starting hard , it takes about 4 seconds to start but drove fine.
Last night and then this morning , when taking off from a light it stutters and trys to stall like im in the wrong gear so i push the clutch back in try to rev it to where its not stuttering then take off . When i got home little bit ago i let it idle and it was fine till i tryed to give it gas and started stuttering .
Back during the summer months every once in a while i would get a code 43 fuel supply code but i havent got it since . i thought it was my 02 sensor bc the wire got a little burnt from my header , and ive read multiple post about 02's causing code 43
Im not throwing any codes when this happens i think my fuel filter may be cloged since it only has a problem from idle
but i wanted a second opinion
thanks
thanks
months ago my car had a stuttering problem also when accelerating from a stop
engine oil got into the cylinders causing mischarges or whatever. Check to see if your gaskets are still in good shape
Also your rotor could be a problem too...i had to change that too to get it fixed
The stock rotor and gasket finally gave up after 17 years
update: sorry it took so long , but i thought you guys might want to know what the problem was ,
my short ram air intake runs really close to my positive post on the battery , i had a cover over it but it fell out so it was shorting out finally one day it just died .
i bought a new battery and relocated it in the back and everything seems to be fine now
khems
Jun 1, 2020 01:51 AM
haroldthefly91crx
Aug 22, 2007 08:56 PM
