The R is home. Impressions of the K20A
Old Jan 6, 2006 | 06:43 AM
DC2R714's Avatar
Default The R is home. Impressions of the K20A
Well the R is finally home. It has been a long time but it was worth the wait. The car feels amazing and the install is flawless.
I came to my friends at http://www.fsmoto.com and told them I wanted a K20A Type R motor with fully functioning PS, A/C, SRS, ABS, etc. After some research and some enginuity they got it all together. (A/C will be fully functional by spring). They spent alot of time making custom brackets and such to make everything flawless (HID Ballast brackets, PS brackets, TB brackets, Rad brackets, FPR bracket) Also alot of wire tucking was done. I can't say enough good things about First State Motorsports. Dan and Josh made this car better than it ever was Turbo. So here are some of my intial impressions so far:
Pros:
-More Torque than a stock B (IVTEC is great. very different and more linear than Vtec from a B)
-Balance of the car feels great
-Throttle response is amazing
-Engine runs cooler from having the header in the back
-6spd tranny leaves for some better daily driving (3800rpms @ 80mph)
-acceleration is very quick
-LSD is strong around the turns
Cons:
-Very expensive swap
-Any motor mounts you can get for this swap are stiff and cause shaking in the cabin
-Alot of modifications have to be done to fit the motor/ accessories in the car
-Custom A/C lines have to be made to run A/C
-Everything for the RSX motors are more expensive than the B series
-Thieves are going to start wanting RSX motors
Overall if you have a great shop do the swap or you do it yourself and take the time to do the research, the swap can turn out great. I am having a blast driving the car and I look forward to seeing the car at an HPDE event this year
Mods are as followed:
Engine:
2004 JDM RSX Type R K20A
9k miles
Drivetrain:
Stock ITR 6spd Tranny
Stock ITR LSD
Exedy Clutch kit
Stock Flywheel
Suspension/Wheels:
Ground Control Coilovers
16" Rota Slipstreams (Royal Gunmetal with polished lip)
Yokohama Parada Spec II 205/45/16
Performance:
DC Sports TSX Header (Bottom half all custom made by FSM because it fit like ****.)
AEM Custom CAI (Fabbed by FSM)
Koyo RSX Radiator
Hasport Motor Mounts
Hasport Stage I axles
Fuelab Fuel Pressure Regulator
Walbro 255lph HP Fuel Pump
Hasport Wiring Harness
Samco Radiator hoses
Apexi World Sport Exhaust
Magnaflow High Flow Cat
Aem Fuel Rail
Earls SS Braided fuel lines with fittings
OEM RSX Type S Power Steering Line
Karcepts Shifter Box kit
Greddy Catchcan
Electronics:
Fuel Pressure Gauge (liquid filled)
OEM DC5R ecu
Show:
TSX Projectors Retrofit
TSX OEM HID Bulbs
E46 M3 HID Ballasts
S2000 6SPD Shift ****
JDM Automatic folding mirrors
Koyo Radiator Cap
VIS Carbon fiber Hood
Smoked Corner lenses
OEM bodykit
Race Pedals
Here are some pics. More pics to come including: ground to oil pan clearance, custom header, HIDs, Interior, Shifter box, etc.
Modified by DC2R714 at 2:04 PM 1/6/2006
Old Jan 6, 2006 | 06:47 AM
PM-Performance's Avatar
Default Re: The R is home. Impressions of the K20A (DC2R714)
Your car always amazes me with cleanliness.
Nice **** you got there Nate.
They look soo funny when you put an intake on them. You gain soooooo much more room.
typer_696's Avatar
Congrats on your getting your back and for it looking so clean and sexy. Enjoy her and keep her safe. I would hate to see that car end up in the wrong place. Your car looks amazing.
Old Jan 6, 2006 | 06:50 AM
DC2R714's Avatar
Default Re: The R is home. Impressions of the K20A (PM-Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PM-Performance &raquo;</TD></TR><TR><TD CLASS="quote">Your car always amazes me with cleanliness.
They look soo funny when you put an intake on them. You gain soooooo much more room. </TD></TR></TABLE>
Thanks Pete. Ya its clean for now but if I start driving it everyday it will get dirty. Ya it is funny how much room is on that side when you dont have the crappy OEM intake hogging all the room
Old Jan 6, 2006 | 06:51 AM
THEUSED's Avatar
Default Re: The R is home. Impressions of the K20A (typer_696)
Old Jan 6, 2006 | 07:05 AM
RTW DC2R's Avatar
way to go nate
Old Jan 6, 2006 | 07:09 AM
whitelightning's Avatar
Default Re: The R is home. Impressions of the K20A (THEUSED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
two thumbs up...maybe one day...currently the b18c5 still puts a grin on my face
Old Jan 6, 2006 | 07:14 AM
Arsenal's Avatar
Default Re: (RTW DC2R)
That intake just doesn't look like it would flow well. It just seems that it goes straight into a 90 degree bend, not a nice staright flow.
In the UK alot of them have just a 5" straight extension off of the intake with the filter on the end, have you looked into this?
Old Jan 6, 2006 | 07:18 AM
DC2R714's Avatar
Default Re: (Arsenal)
The intake was made from a DA CAI and goes straight to the splash guard. This seems to work better at getting colder air than having a straight pipe to the fender. Only dyno tests can prove this. I am hoping to get some baseline runs in very soon.
Old Jan 6, 2006 | 07:29 AM
white rocket's Avatar
Default Re: (DC2R714)
Looks really awesome and super clean. Congrats on getting it all done My friend has the J's K-series crate motor and it's A LOT different than a B-series in terms of drivibility, car feel, etc. 6 speed pwns
Old Jan 6, 2006 | 07:30 AM
MR Dan's Avatar
66.116.69.217
Default Re: (white rocket)
the question is...how much $$$ do I need for the same setup???
Old Jan 6, 2006 | 07:35 AM
JDM Factor's Avatar
Wow nice swap, once the b takes a crap on me, I might have to swap to the K20.
Old Jan 6, 2006 | 07:38 AM
Alexander's Avatar
Default Re: (JDM Factor)
Any shots or measurements of the oil pan clearance?
And how do you plan on passing inspection now?
Old Jan 6, 2006 | 07:40 AM
JDM Factor's Avatar
More pics of clearance, could you lower the car more if you wanted?
Old Jan 6, 2006 | 07:43 AM
DC2R714's Avatar
Default Re: (Alexander)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alexander &raquo;</TD></TR><TR><TD CLASS="quote">Any shots or measurements of the oil pan clearance?</TD></TR></TABLE>
very soon. I haven't uploaded them yet.
Yes I am lowering the front a little more this weekend. There is about 5 1/2in of clearance right now.
Old Jan 6, 2006 | 07:52 AM
ff terror's Avatar
too old for school
Its good to see more and more k swaps into ITR's.
to the fools from a few months back who argued k series would never be what b series was... I think in time it will be the other way around.
Old Jan 6, 2006 | 07:58 AM
cabalistR
Guest
Posts: n/a
Nice swap, im very jealous .. okay maybe JUST A BIT.. i still love the oldschool b18c5.. (iv owned an RSX-S before..)
How much did it set ya back, if you dont mind me asking??
Also, did you sell your c5, or was it blown?? what made you do the swap
Old Jan 6, 2006 | 08:03 AM
DC2R714's Avatar
Default Re: (cabalistR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cabalistR &raquo;</TD></TR><TR><TD CLASS="quote">Nice swap, im very jealous .. okay maybe JUST A BIT.. i still love the oldschool b18c5.. (iv owned an RSX-S before..)
Also, did you sell your c5, or was it blown?? what made you do the swap</TD></TR></TABLE>
I will PM you a price but I do not want to disclose what I have invested.
I sold my Turbo setup and Motor Swap all together and it help pay for this swap.
Reasons I did the swap:
1. Everyone has a turbo now adays and I wanted to be different
2. I want to daily drive the R again and I couldn't see myself doing that with the turbo setup. Although it was reliable as a turbo setup can be. Nothing beats a stock motor for reliability.
3. I was used to driving with 295whp everyday and did not want to go back to a stock R motor making 165-170whp. I needed a little extra power.
4. I would like to do some HPDE events and since I am such a novice I wanted to work with an N/A motor first.
5. I wanted the good midrange torque and peaky top end power all linear from the time I mash the gas.
Old Jan 6, 2006 | 08:04 AM
onyx00's Avatar
As already requested:
HOW MUCH?
Just curious; I need to do something with all that Google stock
Old Jan 6, 2006 | 08:06 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
We all know how much the parts cost to do, but how much was the labor charged and fabrication?
That and all the fabrication is probably what cost the most anyways
A lot of people that have k swaps don't have the functionality of PS, AC, and all the other things you have.
Old Jan 6, 2006 | 08:07 AM
DC2R714's Avatar
Default Re: (MugenHonda)
Labor and Fabrication is around $1500-2500 depending on who you go to.
Old Jan 6, 2006 | 08:15 AM
migs's Avatar
Default Re: (onyx00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx00 &raquo;</TD></TR><TR><TD CLASS="quote">As already requested:
HOW MUCH?
Just curious; I need to do something with all that Google stock </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 &raquo;</TD></TR><TR><TD CLASS="quote">I will PM you a price but I do not want to disclose what I have invested.</TD></TR></TABLE>
Calm down or read.
Old Jan 6, 2006 | 08:16 AM
DC2_MY NUTZ's Avatar
nice
Old Jan 6, 2006 | 08:22 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: The R is home. Impressions of the K20A (DC2_MY NUTZ)
Looks nice!
Forgive my ignorance, but... briefly, what's the difference between the JDM RSX-R motor used here, and the USM RSX-S motor? Not looking for a big technical description, just a 50 words or less kind of thing, and maybe nominal hp/torque figures (not dyno, just stated)... TIA
Old Jan 6, 2006 | 08:26 AM
Ed 341's Avatar
Nice!
I like the gunmetal headlights too
