help! my car won't shift!
Old Jan 6, 2006 | 06:08 AM
liddlelude's Avatar
Default help! my car won't shift!
Seriously, I have to force the shifter into gear(s). My clutch is not disengaging and as of this morning (yeah, this was fun...) I had no resistance or anything to my clutch pedal. I don't know if something is leaking and there's no fluid or what the deal is. Any suggestions?
Old Jan 6, 2006 | 06:17 AM
Missing Gears's Avatar
Default Re: help! my car won't shift! (liddlelude)
check your clutch fluid, if low or empty you have a leak somewhere. most likely either at the slave cylinder, or at the master cylinder which youll also have to look under the dash against the firewall for fluid running down.
Old Jan 6, 2006 | 06:30 AM
liddlelude's Avatar
Default Re: help! my car won't shift! (Missing Gears)
that's pretty much what i'm afraid of. i'm at work so i won't be able to check till later, but i'm leaning toward one of the cylinders leaking.
what's the name of the company that makes mechanical manuals for cars?
Old Jan 6, 2006 | 07:17 AM
you could get a helms or chilton manual, but i would recomend going to the dealer and getting a factory manual.
might be best to take the car to the dealer for service, master cylinders can be a pain in the ***... if youve never done one.
Old Jan 6, 2006 | 02:51 PM
liddlelude's Avatar
does my car (93 prelude) have a hydraulic clutch or a cable clutch?
Old Jan 6, 2006 | 03:13 PM
hydro
Old Jan 6, 2006 | 04:25 PM
SHluder's Avatar
I just made a thread exactly like this.
For me it was my clutch master cylinder. Same symptons as you. I filled up my clutch fluid, let it run for a while. Then took it to the shop. Took them about a day and a half to diagnose my car and repair it. $240 in the end.
Get it fixed though, don't try to drive it. It's not worth breaking something and making this repair more costly then it should be.
Sorry to hear man.
Old Jan 6, 2006 | 11:27 PM
The Phil's Avatar
First, make sure you aren't low on clutch fluid.
Then, bleed your clutch line if you were. Air bubbles = shitty clutch movement = dragging clutch.
Otherwise, check for fluid drainage. Get a FSM and replace it yourself if money is a problem.
Old Jan 7, 2006 | 03:41 PM
liddlelude's Avatar
Default Re: help! my car won't shift! (The Phil)
thanks guys, i actually didn't get to read the rest of your responses till just now. i found a friend to call who basically suggested the same thing.
turns out the reservoir was apparently dry so we put some fluid in it and bled it through the hydraulic cylinder, which temporarily seems to have fixed the problem. but yeah, i'm most likely going to need to replace the cylinder cuz it looks like the boot is leaking anyhow.
now i can't find my manual so what's the difference in someone calling it a "slave" cylinder or a "master" cylinder? are there two or are they the same? wow, i know i sound ignorant but i swear i'm not.
Old Jan 7, 2006 | 04:00 PM
there is a slave cylinder on the trans, and a master on the firewall. it is recommended to replace both at the same time.
mattyfo0z
Apr 2, 2010 12:21 PM
PowerLeg
Jul 21, 2009 02:25 PM
angel949
Nov 26, 2007 08:28 PM
EGPHANTOM
Jun 15, 2005 12:25 PM
93vtec ATL
Jun 5, 2004 10:43 PM
