tranny ?
Old Jan 5, 2006 | 11:54 PM
civic889802's Avatar
Default tranny ?
i have a tranny that has this big *** plus but the old tranny had a cable that connected to the tranny so what do i do my speedometer aint working what can i do any one
Old Jan 5, 2006 | 11:57 PM
90sedan's Avatar
Ummm...
Start by providing more information. Also sentences are your friend.
Old Jan 6, 2006 | 12:11 AM
i have a b16 i dunno what kind of tranny is i havent look at it yet but my speedometer isnt working becouse the tranny has this big hole were the spedometer line goes n my engine bay had a cable wich came with the engine from the old motor is a cable that goes into the tranny
Old Jan 6, 2006 | 06:37 AM
greatwhiteshark's Avatar
You have a cable driven cluster by the sounds of it. You need to find an elecrtonic vss with gearing to fit into your gearbox that you can then connect to the back of your cluster. You should be able to find one from somewhere, but if you can't find one, I have one here taht I'd swap you for postage.
Old Jan 6, 2006 | 09:47 AM
Default Re: (greatwhiteshark)
caN U HOOK IT UP I CANT SEE HOW FATS I AM GOING I GOT PULL OVER 2 TIMES LUCKLY DINT GET NO TICKETS
Old Jan 6, 2006 | 11:21 AM
shadycrx's Avatar
Default Re: (civic889802)
lol at last post
Old Jan 6, 2006 | 11:32 AM
Crimson_Tide's Avatar
Default Re: (shadycrx)
i donT SEE WHATS SO FUNNY ABOUT THE LAST POST
-Josh
Old Jan 6, 2006 | 03:19 PM
so u think u can help me out with my cluster getting it to work will a crx cluster work on a ef
Old Jan 6, 2006 | 04:02 PM
drSquish's Avatar
Default Re: tranny ? (civic889802)
https://honda-tech.com/zerothread?id=1484728
Old Jan 7, 2006 | 05:18 AM
Let me get this straight. Your old box had a cable driven cluster and the cluster is still in your car? And the new box you have, has an electronic vss? If that's the case, take your old cable connector out of the box that you used to have in, and replace it. The one I have is the electronic one so that wouldn't be any good for you if I get you correctly.
Old Jan 7, 2006 | 10:39 AM
yes but is there a way to make the cluster work if i fix the vss thing
Old Jan 7, 2006 | 01:49 PM
drSquish's Avatar
if its a cluster with a cable mount obviously mounted on the back, and you use a cable with a cable vss, it wil work. you cannot convert cable clusters to electronic.
Old Jan 8, 2006 | 10:15 PM
now i have another problem i cant get the shiftlinkage little metal peace that holds it out any one have any good ideas seems to be really stuck
kyorishin
Apr 16, 2006 11:35 PM
You Know I Got SOL!
Aug 22, 2005 12:43 PM
EF9 SIR
Dec 17, 2003 09:36 AM
