Engine oil flush
Old Jan 5, 2006 | 11:40 PM
kornerk12's Avatar
Default Engine oil flush
This question propably seems really dumb. As the tranny and radiator can be flushed out, i have never seen anything like that for engine oil. Is there anything like that or just motor flush that you add before you drain the oil?
Old Jan 6, 2006 | 04:40 AM
rumdig2001's Avatar
Default Re: Engine oil flush (kornerk12)
The product is called oil system cleaner, or OSC for short. put into oil and run engine for five to ten minutes then drain. works well on getting all the sludge out, or most of it.
Old Jan 6, 2006 | 05:13 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: Engine oil flush (rumdig2001)
yup...not recommended for cars over 100k miles though.
Old Jan 6, 2006 | 05:37 AM
The Weather Man's Avatar
Yep. I always run an oil treatment before the oil is changed.
Old Jan 6, 2006 | 05:42 AM
rumdig2001's Avatar
Default Re: (TheKINGPin)
also not recommended to continually use, need to wait 30K miles before doing it again. this stuff usually contains some pretty harsh detergents.
Old Jan 6, 2006 | 08:36 AM
mrOswaldIII
Guest
Posts: n/a
Yeah I would not use it everytime you change your oil. That stuff will eat your gaskets up and that will lead to some oil leaks. I know from experience on an older car .
Old Jan 6, 2006 | 09:10 AM
Default Re: (mrOswaldIII)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrOswaldIII &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I would not use it everytime you change your oil. That stuff will eat your gaskets up and that will lead to some oil leaks. I know from experience on an older car .</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rumdig2001 &raquo;</TD></TR><TR><TD CLASS="quote">also not recommended to continually use, need to wait 30K miles before doing it again. this stuff usually contains some pretty harsh detergents.</TD></TR></TABLE>
Well - the reason I do so is because i let my car sit a lot. It takes me many months to travel 3,000 miles - so in my case, its perfectly fine. I'd probably let my car sit for a month or so - drive it, let it sit........etc.
alispoon
Nov 25, 2007 09:44 AM
Vouthanack
Jul 30, 2004 11:18 AM
HUBB
Apr 26, 2004 03:52 PM
Arsenal
Apr 19, 2004 04:10 PM
tensai717
Dec 9, 2001 03:49 PM
