JDM b16a swap WITH papers
Old Jan 5, 2006 | 11:09 PM
rough_draft's Avatar
Default JDM b16a swap WITH papers
Motor was bought from JDM import direct in tacoma. I have the receipt for it, its a 100% legit motor. Comes with b series axles, it has an obd2 distributor, obd2 injectors. ALl you need is a shift linkage and possibly wire harness depending on what its going in to. This motor is clean! The motor is located in Federal way, make some offers i need it gone! Thanks
Old Jan 5, 2006 | 11:11 PM
also! comes with ecu( p2t or p73, the itr ecu will cost you more), and mounts! someone swoop this up!
Old Jan 6, 2006 | 10:14 AM
up up & away
Old Jan 7, 2006 | 06:44 PM
Shelton's Avatar
Default Re: (rough_draft)
pm sent!
TDSI99
Apr 21, 2007 11:07 AM
jdmjoelol
Sep 24, 2005 09:41 PM
