4x114 and 5x114
Old Jan 5, 2006 | 09:10 PM
SOHC_me's Avatar
Default 4x114 and 5x114
what is there difference between them besides the lug pattern? Like are the brakes bigger on one, or better? becouse i found 4x114 setep for pretty cheap verseus the 5x114 that go for $900
Old Jan 5, 2006 | 09:14 PM
migs's Avatar
Default Re: 4x114 and 5x114 (dc_mike)
4x114.3 brakes are the same size as GSR
5x114.3 brakes I believe are 11" in diameter
4x114.3 setups are cheaper because they are in less demand.
Old Jan 6, 2006 | 01:00 PM
98 Spec R's Avatar
Default Re: 4x114 and 5x114 (migs)
I have heard that the wheel bearings for the 4 X 114 setups are different. If you need them you are SOL unless you can order them from Japan.
Old Jan 6, 2006 | 01:16 PM
migs's Avatar
Default Re: 4x114 and 5x114 (98 Spec R)
Wheel bearings are both the same.
You are talking about the 98+ JDM ITR where it uses a 36mm axle nut versus the smaller 32mm.
Old Jan 7, 2006 | 06:30 AM
JDMcb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">4x114.3 brakes are the same size as GSR
4x114.3 setups are cheaper because they are in less demand.</TD></TR></TABLE>
acually no you wouldnt be SOL all you need is Prelude SRV rotors (4th gen Prelude Vtec for you guys in the states) , Calipars from prelude vtec, 5th gen Prelude, Accord wagon, and a 3 mm spacer and everything should bolt up and work and voila! you have yourself a cleap poor mans BBK as well you can order rotors at your local parts shop :D
Simple SOHC
Jun 24, 2007 09:19 PM
GIANT
Mar 14, 2006 09:42 AM
jetpilot
Dec 17, 2004 01:32 PM
Fuzion
45
Sep 13, 2003 05:32 PM
hybrid901
Feb 24, 2003 10:46 AM
