conical/flared pipe
Old Jan 5, 2006 | 09:09 PM
FURACERMAN's Avatar
Default conical/flared pipe
I'm interested in making some conical pipe. What methods are used to make it, and/or where do you guys get it from? Thanks!
Old Jan 5, 2006 | 11:45 PM
supercreed2002's Avatar
Default Re: conical/flared pipe (FURACERMAN)
I think you might have to have some machine shop skills and tools to do this....
Old Jan 6, 2006 | 12:06 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: conical/flared pipe (supercreed2002)
take a piece of flat ss... 16 gauge or what ever, roll it up like a triangle (will take metal working tools/experience) once you get the desired length/diameter/whatever tack it up and cut it... pretty simple
Old Jan 6, 2006 | 03:59 PM
Sikocivic's Avatar
We made some cone shaped pipe one time. We had a peice of solid steel that was in a cone shape(I don't know where it came from) and we used a press and a torch to force the pipe down onto the solid peice. It sounds getto, but they came out OK. Turned 2" pipe into a 2"-3" flare pipe.
Old Jan 6, 2006 | 06:32 PM
david@didrace.com's Avatar
We use a hydraulic swage with a cone die that is built into our rotary-draw bender. Any of the above ways work great though.
stillsmokey
Dec 28, 2007 12:37 PM
TurboSI56
Welding / Fabrication
Aug 12, 2006 08:40 AM
r0yal
Apr 19, 2006 07:03 PM
