H22a4 spec S pistons
Old Jan 5, 2006 | 06:20 PM
sprayedlude93's Avatar
Default H22a4 spec S pistons
I have a h22a4 2001 block with 2-3k on it. I got it from Honda about a yr ago. I am going to slap it onto a head I got. I am going n/a. if i would get type s std pistons can i use my rods? I heard the stock rods are good for over 400hp and i am only look at like 220-230whp so about 270 crank. let me know. thanks
Old Jan 5, 2006 | 07:01 PM
Fly1865's Avatar
Default Re: H22a4 spec S pistons (sprayedlude93)
Yes you can use them and no they won't last with 400 hp
Old Jan 5, 2006 | 07:08 PM
CivicSiDriver02's Avatar
Your rods should be fine if you are going to go all motor. If you are planing on reving it to the moon then you may want to invenst in some forged rods.
Old Jan 6, 2006 | 12:28 PM
Default Re: H22a4 spec S pistons (CivicSiDriver02)
I am going to be pushing about 220-230whp and revving to between 8-8500rpm's. not all the time ofcoarse. Just on track weekends. Will the rods hold up ?
Old Jan 6, 2006 | 12:34 PM
92hondalude's Avatar
what more are you going to put in the motor?
cause type s pistons on a stock motor is only going to get you 223 flywheel HP not WHP
Old Jan 6, 2006 | 12:56 PM
Default Re: H22a4 spec S pistons (92hondalude)
ok here's what I have for the head (already done) it's the block I am working on
H22a1 93 head
Ferrea stainless steel valves
CROWER DUAL SPRINGS + RETAINLER KIT
Type S cams
Aem cam gears
3 angle valve job
port and polish
welded and reshaped the combustion chambers
ep3man
K Series
Aug 30, 2010 11:38 AM
PnkRokCountryboy
17
Nov 20, 2005 04:08 PM
GOIN V8 HUNTIN
Nov 8, 2005 06:13 PM
mini-cRx
Apr 28, 2004 05:08 AM
typeSwarrior
Feb 7, 2002 02:45 PM
