SUSPENSION!!!
Old Jan 5, 2006 | 03:08 PM
BrokenRex
Guest
Posts: n/a
Default SUSPENSION!!!
Does anyone know where i can pick up a decent set of suspension for under 700, shocks struts, and coilovers?????
Old Jan 5, 2006 | 03:31 PM
crexer's Avatar
Default Re: SUSPENSION!!! (Br0KeNCRX)
omni power.
Old Jan 5, 2006 | 03:42 PM
BrokenRex
Guest
Posts: n/a
Default Re: SUSPENSION!!! (crexer)
I heard omni power is expensive. Decided to check stuff out on egay and I see tokiko blues for 209.00, alluminas for 309.00, and ground controls for 250..... Whats the big difference between the two shocks ? ? ? ? Also Like I said I have shitty *** suspension, would I most likely need bushings ? ? ?
Old Jan 5, 2006 | 03:48 PM
BrokenRex
Guest
Posts: n/a
Ok, nm on the omni . . . . Should I go with the Blues/GC(500.00), Illumina/GC(625.00), or the Omni Full kit(700.00)
Old Jan 5, 2006 | 03:49 PM
runeminaEF9's Avatar
you said under 700. omni power right around that price for a full coilover set. they will also perform much better than any strut/spring combo you piece together. if you were gonna go with any set of struts though, i would say invest in koni, because they can be revalved at a later date if needed.
Old Jan 5, 2006 | 03:59 PM
BrokenRex
Guest
Posts: n/a
Default Re: SUSPENSION!!! (runeminaEF9)
I think im gonna go w/ the Omni, should I get street(F10/R8), or sport kit(F12/R10)?????
Old Jan 5, 2006 | 04:02 PM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br0KeNCRX &raquo;</TD></TR><TR><TD CLASS="quote">I think im gonna go w/ the Omni, should I get street(F10/R8), or sport kit(F12/R10)?????</TD></TR></TABLE>
What do you do with your car? How hard of ride do you want? I would say for DD street is what you want.
Old Jan 5, 2006 | 04:24 PM
crexer's Avatar
Default Re: SUSPENSION!!! (CRX Toad)
definately go with the omni powers, the tokico's are no good neither is kyb or any other stuff when compared for a full coilover setup for not much more. I have tried tokico blues, illuninas, gr2's, skunk2 coils, h&r, etc. I can tell you that with the price I spent on all those shock/spring combos i could have had 2 sets of full coilover setups now. My friend just scored a set of omni's for an EK and they are friggin awesome. Quality is awesome and ride is like 2 times better than stock. You will not be disappointed with omni's.
Old Jan 9, 2006 | 01:36 PM
kaychi's Avatar
i saw on ebay the skunk2 has a set of coilovers and shocks for 585. im thinking about getting it but dont know if it's good or not
xgenn786
Sep 28, 2005 06:01 AM
sd.coupe
12
Aug 4, 2004 04:42 PM
nfiedler3
Jan 6, 2003 09:16 AM
1.8T_EG
Sep 6, 2002 10:19 AM
nickgomez
21
Jan 4, 2002 09:22 PM
