Were can I buy exhaust flange?
Old Jan 5, 2006 | 01:53 PM
577HondaPrelude's Avatar
Default Were can I buy exhaust flange?
I need just a flange. the one on the end of a down pipe. Know of any places that sell the flange only? I tried local Auto parts stores and auto shops. They only sell pre-made pipes with the flanges on them.
specifically I need something close to this:
Old Jan 5, 2006 | 02:23 PM
CvillEMechAnic69's Avatar
Default Re: Were can I buy exhaust flange? (577HondaPrelude)
i would look on the honda website and get the honda parts number to see if they have it
Old Jan 5, 2006 | 03:10 PM
Default Re: Were can I buy exhaust flange? (CvillEMechAnic69)
they don't sell the flange.. it's welded to the exhaust down pipe, and the stock ID would be 2.25" not 2.5".
Old Jan 5, 2006 | 03:13 PM
eastbay92cx's Avatar
2.5" 3 bolt flange $1.99 from jcwhitney.com, or else you might get lucky if they have some collector flange kits at kragen in the performance section, check it out. Good luck.
Old Jan 5, 2006 | 03:21 PM
JG-Fabrications's Avatar
Default Re: Were can I buy exhaust flange? (eastbay92cx)
We make custom flanges all time, give sam a call at 281 856 0400 or email at sales@bmcrace.com for a quote
-James
Old Jan 5, 2006 | 03:56 PM
tony1's Avatar
Default Re: Were can I buy exhaust flange? (JG-Fab)
Exploited Racing....LOL
Old Jan 5, 2006 | 05:03 PM
bigTom's Avatar
Default Re: Were can I buy exhaust flange? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Exploited Racing....LOL </TD></TR></TABLE>
Old Mar 8, 2006 | 10:01 AM
Kool-Lude's Avatar
Walter...did you ever find that flange? SMSP (Dave) has that exact flange, or at least I'm pretty sure its very close to 2.5" ID. He had them made specifically for our unique Prelude header flange bolt pattern. Contact Dave.
Old Mar 8, 2006 | 09:51 PM
snowseeker's Avatar
Old Mar 9, 2006 | 06:00 AM
Default Re: Were can I buy exhaust flange? (Kool-Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kool-Lude &raquo;</TD></TR><TR><TD CLASS="quote">Walter...did you ever find that flange? SMSP (Dave) has that exact flange, or at least I'm pretty sure its very close to 2.5" ID. He had them made specifically for our unique Prelude header flange bolt pattern. Contact Dave.</TD></TR></TABLE>
I just got off my lazy *** and fabed one up myself, rather than buy one.
Old Mar 13, 2006 | 09:16 AM
Kool-Lude's Avatar
Here's the one Dave made...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">Got the house flanges in today for 2-1/2" prelude cats.
Stock flange on the right, if anyone didn't know
Dave's flange (above left) has an ID slightly larger than 2.5", to fit OVER a 2.5" ID cat.
How did you fab yours...drawing and lazer cut? And did you make it exactly 2.5"ID, or a little smaller or larger?
Old Mar 14, 2006 | 06:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">How did you fab yours...drawing and lazer cut? And did you make it exactly 2.5"ID, or a little smaller or larger?</TD></TR></TABLE>
We had some extra 1/2" thick SS sheets at work. I printed out a 1:1 drawing with Auto-CAD, cut it out and use it as a template. Then went to our mettle cutting band saw and made a rough cut, then spent a little time on the grinder to smooth it out to the template lines. Then drilled the holes on the drill press. The 2.5" middle hole was done with our lathe. It was just a quick and dirty process.
My center hole was abut 2.5" Diameter for only 1/2 the way down into the flange, then a little smaller the rest of the way (to match up with the ID of the pipe). This way the pipe had a little socket to fit down into, but not go all the way through the flange. Then it was 360deg. tig welded to the pipe.
It's good to work at a place with lots of "toys"
Some times I just get lazy and would rather pay someone else for the work.
Honda4life777
Jun 28, 2009 08:43 PM
hatchinprogress
Welding / Fabrication
Mar 19, 2006 03:17 PM
hatchinprogress
94TurboGSR
Sep 21, 2003 10:51 PM
EK22Tim
Oct 30, 2002 08:09 PM
