wing raise
take off the wing. theres two 10mm nuts on each side when you open the hatch. then once you have it off put two of the nuts back on the studs one on each side towards the back of the car then put the wing back on useing only the two remaining nuts and yes only two will hold it. or just put some washers on the two back studs for a less jdm look
GSRwBOOST
Dec 21, 2002 10:49 PM
