150 wheel horse power for cheap
Old Jan 5, 2006 | 09:55 AM
driveahonda's Avatar
Default 150 wheel horse power for cheap
What you be yalls suggestions on getting easiest and cheapest 150 whp n/a in a obd0 crx si....
- single cam vtec with bolt ons
- b18b swap with bolt ons
(i figure these two would be the cheapest)
who has 150whp with one of these 2 motors... and what bolt ons are on it...
Old Jan 5, 2006 | 10:13 AM
D-Rob's Avatar
Default Re: 150 wheel horse power for cheap (driveahonda)
Neither of those will net 150 wheel horsepower.
Your best bet it either a GSR swap (B18C1) or ITR swap (B18C5).
Old Jan 5, 2006 | 10:27 AM
im not being a dick... but read a little more carefully... im not talking about leaving them stock... which one will make the power of 150 for the cheapest price
Old Jan 5, 2006 | 10:30 AM
97L-esVeeTeg's Avatar
Default Re: (driveahonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driveahonda &raquo;</TD></TR><TR><TD CLASS="quote">im not being a dick... but read a little more carefully... im not talking about leaving them stock... which one will make the power of 150 for the cheapest price</TD></TR></TABLE>
Between the two the LS would probably be the better route to go.
Cams, bolt ons, and tuning should have you there
Old Jan 5, 2006 | 10:33 AM
D-Rob's Avatar
Default Re: (97L-esVeeTeg)
Regardless, with the mods you listed on each motor, neither will net you 150whp. Maybe you should read your own posts, as well as the replies you recieve more thoroughly before spouting off dumb comments.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97L-esVeeTeg &raquo;</TD></TR><TR><TD CLASS="quote">
Cams, bolt ons, and tuning should have you there</TD></TR></TABLE>
Yes, cams, bolt-ons and tuning would get you there on an LS motor.
Old Jan 5, 2006 | 10:36 AM
is this cheaper even with the swap price figured in?
Old Jan 5, 2006 | 10:40 AM
D-Rob's Avatar
is this cheaper even with the swap price figured in?</TD></TR></TABLE>
More than likely not. My suggestion to you is, if you're set on the LS swap, get a B18A swap from a OBD-0 Integra and swap it in.
That would cause the least headaches.
Old Jan 5, 2006 | 10:44 AM
sa90eg's Avatar
b16 will be your best buy
b16a w/gsr head
ctr pistion/itr cams /spoon gears/skunk iM/jg66mm tB/jdm itr header
made 174hp 115 tq
https://honda-tech.com/zerothread?id=1479453
Old Jan 5, 2006 | 11:11 AM
Surubasi00's Avatar
Default Re: 150 wheel horse power for cheap (sa90eg)
Why the GSR head? the B16a has aperfectly good head on it in the first place
N/M I posted before i read the whole thing...
Dave
Old Jan 5, 2006 | 04:15 PM
xEnderx's Avatar
Default Re: 150 wheel horse power for cheap (Surubasi00)
An ITR or B16B will net you 150+ right out of the box. No tuning, no cams, no bolt on blah blah blah. Plus they will be 100% reliable. If your goals are nothign beyond 150, then I'd STRONGLY reccomend a stock R swap of some type.
Old Jan 5, 2006 | 05:16 PM
89s1's Avatar
Default Re: 150 wheel horse power for cheap (xEnderx)
i bought a used b16a and it put down 154 with intake and exhaust.
vtec
Old Jan 5, 2006 | 06:12 PM
skylinetph26's Avatar
Default Re: 150 wheel horse power for cheap (89s1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">i bought a used b16a and it put down 154 with intake and exhaust.
vtec </TD></TR></TABLE>
Did you do some type of tuning? If not thats crazy
Old Jan 5, 2006 | 06:43 PM
89s1's Avatar
Default Re: 150 wheel horse power for cheap (skylinetph26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylinetph26 &raquo;</TD></TR><TR><TD CLASS="quote">
Did you do some type of tuning? If not thats crazy </TD></TR></TABLE>
nope no tuning. Part of me thinks i got lucky and imported an n1 engine though. All the internal components are stock as far as i can tell, but it put down over 105 ft/lbs from 5,500 up to 7,700 peaked at 109.6 ft/lbs @ 5766 rpm. If you ask me thats a bit low for a b16 to be making all of its torque
Old Jan 5, 2006 | 06:56 PM
g-ride-si's Avatar
a b16 head is almost a bolt on for the ls motor. could get you pretty close to 150 hp if not there.
Old Jan 5, 2006 | 07:12 PM
xEnderx's Avatar
Default Re: (g-ride-si)
$3500 for a B16B swap plus 200 for mounts and then maybe another 200 in BS for the swap. Under 4 grand and you've got easily 155 WHP and an AWESOME transmission combined with factory reliability and the ability to rev to the sky. Its a no brainer there buddy.....but feel free to build sometthing else if you'd like.
Old Jan 5, 2006 | 08:17 PM
biassj's Avatar
Default Re: (xEnderx)
Why not a B18C1? I've seen stock GSR's dyno just under 150. Thats with stock box, ps, ac, blah, blah. If it's a hatch you throwing it in, most likely you won't have those accessories. With bolt ons, you can get 155-160 easily.
To answer your question, the LS will be the cheaper route. Getting a D16 to around 150 is pretty hard. Probably have to go down on your internals. It'll be hard to hit with 150 with just bolt ons with LS also.
Old Jan 5, 2006 | 09:31 PM
FURACERMAN's Avatar
Default Re:
http://www.pgmfi.org/twiki/bin...ccess
B18A/Bs seem to be pretty potent motors when in the right hands.
Old Jan 5, 2006 | 11:06 PM
90sedan's Avatar
To put down 150whp expect to pay around 3,500 - 5k, whether it's from a built d16 or a b18 it will be somewhere around there.
Why not just swap a z6 in and boost it?
or better yet just boost your a6.
Old Jan 5, 2006 | 11:14 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (89-civic-DX)
for the price of an ls , you can build a turbo setup that will make you much more than 150whp .....oh crap im in the all motor forum.
Old Jan 5, 2006 | 11:31 PM
crx2nr822's Avatar
Default Re: (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">for the price of an ls , you can build a turbo setup that will make you much more than 150whp .....oh crap im in the all motor forum.</TD></TR></TABLE>
HAHAHAHAHAHA
Old Jan 5, 2006 | 11:54 PM
g-ride-si's Avatar
dont know where you can put together a turbo set up for less than $150 thats what ls motors cost around here.
Old Jan 5, 2006 | 11:57 PM
ATS*Mark's Avatar
OG triple OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g-ride-si &raquo;</TD></TR><TR><TD CLASS="quote">
dont know where you can put together a turbo set up for less than $150 thats what ls motors cost around here.</TD></TR></TABLE>
wow id love to go there.
Old Jan 6, 2006 | 12:07 AM
g-ride-si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">wow id love to go there.</TD></TR></TABLE>
st louis MO, they even take them out for you. maybe i should start selling them...
Old Jan 6, 2006 | 12:13 AM
ATS*Mark's Avatar
OG triple OG
definatly.
Old Jan 6, 2006 | 04:09 AM
xEnderx's Avatar
Default Re: (biassj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biassj &raquo;</TD></TR><TR><TD CLASS="quote">Why not a B18C1? I've seen stock GSR's dyno just under 150. Thats with stock box, ps, ac, blah, blah. If it's a hatch you throwing it in, most likely you won't have those accessories. With bolt ons, you can get 155-160 easily.</TD></TR></TABLE>
Becasue the GSR doesn't have a main girdle, it doesn't have the better thermostat, the better water pump, the awesome cams.....oh yeah, not to mention how absolutely off the chain the R transmission is. Trust me, B16B &gt; GSR swap. Might make roughly the same POWEr, but there's alot or to a motor than the numbers it spits out on the dyno.
