Type R Cams?
I'm looking into getting a set of these cams off a local guy. They are used.
What exactly should i look for as to wear to make sure they are still in good shape? And also will there be a stamp on them to confirm they are Type R?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StReEt TuNeR »</TD></TR><TR><TD CLASS="quote">look for rings on the intake cam on the distributor side</TD></TR></TABLE>
Not that easy.
make sure they look like this
AND NOT LIKE THIS
Not that easy.
AND NOT LIKE THIS
Interesting. So that would differentiate the cams. The pictures show a little bit different ends on the cams. So now what should i look for to make sure they are still in good shape?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Karizmah »</TD></TR><TR><TD CLASS="quote">Bump for some info
what else do you need to know? that diagram is quite helpful, i referred to it when i bought my CTR cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">Everyone gets fucked and ends up with B17a cams. It's happened to 3 people I know.</TD></TR></TABLE>
Stop acting like you're not directing that at me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">is there a difference between all the CTR and ITR cams from different years?
Or all they all the same? If there is a diff, which is best?</TD></TR></TABLE>
CTRs and 00-01 ITRs are the same but 97-99 had like a less duration or less lift I forgot which. I have the link of the specs at home, I'll post it later
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">CTRs and 00-01 ITRs are the same but 97-99 had like a less duration or less lift I forgot which. I have the link of the specs at home, I'll post it later</TD></TR></TABLE>
so CTR and 00-01 ITR will provide more power correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BACKintheDA »</TD></TR><TR><TD CLASS="quote">
What im looking for are specific wear patterns that aren't good. Like somthing on the lobes.......
</TD></TR></TABLE>What im looking for are specific wear patterns that aren't good. Like somthing on the lobes.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">the lobes should look like teardrops. If the lobe has flats spots on it near the point, even subtle flats, thats a sign of wear.</TD></TR></TABLE>
Thanks i'll look for that.
yes...um maybe
... CTR & '00-'01 ITR cams have 3 more degrees of duration
I think
</TD></TR></TABLE>yes...um maybe
I think
