My car is lowered 2" on springs, does this offset the speedo?
Old Jan 5, 2006 | 05:52 AM
cabalistR
Guest
Posts: n/a
Default My car is lowered 2" on springs, does this offset the speedo?
I was wondering if lowerig the car messes with the speedo??
My GPS reads about 10km/h less then what it actually says on the speedo in the car, i tried it out in my moms car and the gps and speedo were exactly correct....
hmmmmmm??????
Old Jan 5, 2006 | 05:53 AM
migs's Avatar
Default Re: My car is lowered 2" on springs, does this offset the speedo? (cabalistR)
No.
Old Jan 5, 2006 | 05:55 AM
cabalistR
Guest
Posts: n/a
I don;'t understand why my GPS is 10km/h slower.. if ill be doing 150km/h my GPS says 142-143...
In my rental the civic i had, and my moms car the GPS and speedo are EXACT....
I don't know much about speedometeres, but does it have to be recalibrated or whats going on ???
Old Jan 5, 2006 | 05:56 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: (cabalistR)
wrong tire sizes?
cabalistR
Guest
Posts: n/a
nope, they are 195/55/15s
Old Jan 5, 2006 | 05:59 AM
Bbasso's Avatar
SIlly...
It's because the R is so fast the GPS can't keep up!
Old Jan 5, 2006 | 06:01 AM
cabalistR
Guest
Posts: n/a
Hahahaah, I think Bbasso nailed it
Old Jan 5, 2006 | 06:50 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cabalistR &raquo;</TD></TR><TR><TD CLASS="quote">I don;'t understand why my GPS is 10km/h slower.. if ill be doing 150km/h my GPS says 142-143...</TD></TR></TABLE>
Sounds like the difference is 7-8 km/h. And what are you doing looking at your GPS when you're going over 90 mph, anyway?
That's a difference of roughly 5 percent, which is more than normal, but not exactly huge. Speedometer error can arise from many different sources, even with tires that are nominally the stock size (not all of which are exactly the same size). For example, the difference in the outer diameter of your tires (which affects the accuracy of your speedometer) between brand new tires and tires that are worn down to the treadwear indicator bars is 2 percent.
Old Jan 5, 2006 | 07:15 AM
Bradstard's Avatar
Mine is off about the same amount using GPS in my ITR. My Toyota Tacoma is dead on though...
Old Jan 5, 2006 | 01:23 PM
Kavehman's Avatar
well if it makes any diff.
when i dynoed my car it was showing 110km/hr on the dyno and speedo was showing 120km/hr
Old Jan 5, 2006 | 02:41 PM
cabalistR
Guest
Posts: n/a
Cool guys, interesting points and i guess it confirms its not only my car...
Thx
arihakan
Suspension & Brakes
25
Jan 30, 2008 02:56 PM
NtheWorks
May 14, 2007 05:35 PM
MHSD
18
Jan 23, 2007 08:05 AM
ekcivic9
Suspension & Brakes
Mar 30, 2006 04:28 PM
watsvtecEK
Dec 16, 2005 08:44 AM
