wich cams wich head?
Hi
at first sorry about my english. hope some of you understand what i am talking about
my car is a crx ee8 with a b18c6 block from a itr.
the block is pretty stock.
i have a 4-2-1 header with 60mm collector.
from there a 60mm catback.
a b16a1 head with b16a2 intake mainfold and 65mm throtlebody.
now my problem.
the car pulls only 185hp
the tourqe is ok with 195nm
i want to pull out about 200hp or more
should i go for a itr or gsr head?
wich cams would u use?
blox hsl?
and wich cams can i use with less work on head (cams, retainers, valve springs, cam gears) and no work on the block?
hope some specialists can help.
thank you
now my problem.
blox hsl?
thank you
your best bet would go with a Type R head and either 00-01 itr cams or ctr cams. b/c it has the highest lift of any honda oem cam and you can still keep the stock itr valve train. thats if you dont wanna get an upgraded valve train.. then i would go w/ supertech valve train (same company as skunk 2) and i would go w/ skunk2 stage 2 cams
Hope this helps
Hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff »</TD></TR><TR><TD CLASS="quote">your best bet would go with a Type R head and either 00-01 itr cams or ctr cams. b/c it has the highest lift of any honda oem cam and you can still keep the stock itr valve train. thats if you dont wanna get an upgraded valve train.. then i would go w/ supertech valve train (same company as skunk 2) and i would go w/ skunk2 stage 2 cams
Hope this helps</TD></TR></TABLE>
i have tried to find some infos here about the hsl cams but found nothing.
can you tell me where to find the infos about problems in using the blox cams?
thank you
thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec »</TD></TR><TR><TD CLASS="quote">i have heard of problems with using blox cams
From where? Are you sure you aren't thinking of OBX?
To the thread starter: Our M22 series would work well
</TD></TR></TABLE>From where? Are you sure you aren't thinking of OBX?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer »</TD></TR><TR><TD CLASS="quote">To the thread starter: Our M22 series would work well
Rocket cams kick ***
</TD></TR></TABLE>Rocket cams kick ***
92integraVTECgsr
Sep 26, 2010 05:02 AM
known
Jun 12, 2006 03:49 PM
