@@@Jdm ITR Redline???? Help!@@@@
What is the redline to a stock jdm itr motor??? ok so here it is. i have a 98' jdm itr swap with only exuast,stock headers,intake, and stock ecu. ive tried to redline it but when it gets close to around 7900k my motor sounds like its kind of over revving already especially in 1st. but sumtimes it'll hit 8200k just fine in 2nd, 3rd, etc...the sound that it makes when that happens i can't really describe...my only best descripition is that of a over revving soud or its getting close to that point at times really doesn't sound like it should be doing that. what do you guys think the problem is? should i get this checked out soon at a shop???? help is need! thanks in advance!
if its the JDM then it should redline at 8900 but i change my ecu so it rev to 10000rpm trust me reving this high u don't get power out of the engine
The redline is the same as the USDM ITR, unless I am mistaken...
8400 RPM, I think.
I know for sure the rev-limit is at 8600 RPM. I used to run a JDM ITR ecu in mt B16-swapped coupe.
8400 RPM, I think.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC2_2001 »</TD></TR><TR><TD CLASS="quote">if its the JDM then it should redline at 8900 but i change my ecu so it rev to 10000rpm trust me reving this high u don't get power out of the engine </TD></TR></TABLE>
Correct out of a stock b18 but throw some aggressive cams and shift the powerband upward.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fresh[EK9 »</TD></TR><TR><TD CLASS="quote">]already searched. found nada.</TD></TR></TABLE>
Then either I don't think you know how to search, or I don't believe you. This topic was covered a week ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opie »</TD></TR><TR><TD CLASS="quote">FAQ's thread is your friend.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob »</TD></TR><TR><TD CLASS="quote">8400 RPM, I think. </TD></TR></TABLE> WRONG! hehe its 8399 to be exact. the tach will show 8800 on the needle, but you motor will not go past 8400 on a stock ECU. hook a timing gun up and tell me if you see anything more then 8399. (a Snap On one though.) none of the kragen ones. or even a VAFC will tell you. since everything is digital, and not analog like your shitty factory tachometer is.
Both USDM and JDM ITR's have the same fuel cut.
The problem lies with the factory tachometer. Indicated on the tach is approx 8900rpm's, but as you now know, the factory tach is nothing near accurate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">Both USDM and JDM ITR's have the same fuel cut.
The problem lies with the factory tachometer. Indicated on the tach is approx 8900rpm's, but as you now know, the factory tach is nothing near accurate.</TD></TR></TABLE> yee yee raise dah rooph for dah tru jdm redline G!! hehe...it is in fact 8399, correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by #1151 »</TD></TR><TR><TD CLASS="quote"> WRONG! hehe its 8399 to be exact. the tach will show 8800 on the needle, but you motor will not go past 8400 on a stock ECU. hook a timing gun up and tell me if you see anything more then 8399. (a Snap On one though.) none of the kragen ones. or even a VAFC will tell you. since everything is digital, and not analog like your shitty factory tachometer is. </TD></TR></TABLE>
...Funny, I had a V-AFC2 on my B16 and it verified 8600 RPM as the fuel cut.
fuel cut off at around 8399k sounds right. thats close to what it showed on my 99-00 si guage cluster. thanks for all the help guys!!! by the way, i want to get rid of my stock p73 ecu and i was wondering who chips really good P28, etc... ECU'S??? got any suggestions on people on h-t members or non h-t members????
lol i want to rev up to 9k plus!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmr_neil »</TD></TR><TR><TD CLASS="quote">97 jdm itr with stock ecu using a apexi RSM to monitor the rev output pulse from ecu
proof!!!!!
...That also states your speed was 145mph.
All I know is, when I ran my JDM P73, it wouldn't let me rev past 8600 RPM, which LOOKED LIKE 9000 RPM on my CTR cluster's tach.
proof!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1354826
https://honda-tech.com/zerothread?id=394719
https://honda-tech.com/zerothread?id=217929
...Told you guys.
8600 RPM is fuel cut. 8400 RPM is 'redline.'
...Told you guys.
