do i used the same bearing on my stock diff. for the obx lsd??
putting in an obx lsd to my b16 tranny. just wonder if i can use the stock bearing on the stock diff. or will it not fit? was planning to press out the bearing and put it on the obx.
its good to buy new ones anyways...you dont want one to go bad and make the diff wobble....if so oyu can say bye to your final drive and counter shaft....
make sure you measure the clearence with the case and use the proper shim if needed....
dont forget the final drive bolts are reverse thread and put on the speedo gear!!
will it be better to replace the tapered roller bearing
with the ball bearing? i have not open my del sol b16 yet, but does it come with tapered roller bearing or ball bearing?? if i replace the bearing with ball bearing will it still fit the tranny housing? what is a speedo gear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg:R »</TD></TR><TR><TD CLASS="quote">will it be better to replace the tapered roller bearing
with the ball bearing? i have not open my del sol b16 yet, but does it come with tapered roller bearing or ball bearing?? if i replace the bearing with ball bearing will it still fit the tranny housing? what is a speedo gear?</TD></TR></TABLE>
gsrs are the only ones that have tapered roller bearings ... replace it with new factory bearings of the same kind....
you need to measure the bearing to case clearence and theres a speedo gear on the old diff that will need to be put on the lsd
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
is anyone have trouble getting there axles out anymore? i want to but one for my hatch cause 99hybrid_hatch has had his for a long time.is it still working good for you?
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QwIkEf »</TD></TR><TR><TD CLASS="quote">is anyone have trouble getting there axles out anymore? i want to but one for my hatch cause 99hybrid_hatch has had his for a long time.is it still working good for you?</TD></TR></TABLE>
no, that problem was fixed.... obx forgot to bevel on side of the diff, thats why axles were getting stuck.
the new gen2's or wahtever have both sides beveled to get rid of the sticking problem
my obx diff has both sides beveled
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">i got new bearings for mine. i would get them even if you can pry the old ones off.
platinum.</TD></TR></TABLE>yea, i actually managed to pull mine apart by hand
the biggest bitch is going to be getting the final drive off of my old stock diff because i dont have a vice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">the ones that fit on the diff... whatever it came with stock, which im assuming are the taper roller bearings</TD></TR></TABLE>
i believe only gsrs have tapered roller bearings... the b16 and Ls use ball bearings similar to the itr and 2001 gsr but smaller
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch »</TD></TR><TR><TD CLASS="quote">yeah my diff is still kicking ***!!
I will post pics of what I did to a final drive to show Iam not babying this sucka..</TD></TR></TABLE>
i believe you ....you should see my 3rd and 4th gear i just had to change
lol
