How to replace clutch on an LS in an EF?
Can I just pull the trans off or do I have to pull the motor? If I have to pull the motor is it better from the top or the bottom?
Pull the suspention, axles, shift linkage/cable, fluid, and probably the passenger radius arm. Drop the trans, then do the clutch.
i found it much easier to pull the whole motor out and change it because of the limited room and not having a lift to get the car high enough and i pulled every hose, all fluid and axles pulled out and i had to swap the tranny not clutch then put it back in and had it running in 2 and half hours
VeeSykkz
Apr 8, 2016 11:39 AM
kingcu90
25
Jun 18, 2009 09:35 PM
DC4 ENTHUSIAST
Nov 18, 2008 09:08 AM
