Omni suspension
Old Jan 4, 2006 | 10:09 PM
Shake and Bake's Avatar
Default Omni suspension
I just ordered the omni full coilovers and wanted to know how hard it will be to install. I also heard that the bolts break real easy. Is that true?
Old Jan 4, 2006 | 10:30 PM
Turbo_y8's Avatar
Default Re: Omni suspension (AllstockSIke)
break?? we all wish they did, youl just round the heads on the rear lower shock bolts and then we all swear, and think about it with a beer
Old Jan 4, 2006 | 10:48 PM
Mugen112's Avatar
As long as you know what your doing, its a piece of cake!
Old Jan 4, 2006 | 11:22 PM
dtran002's Avatar
Default Re: (Mugen112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen112 &raquo;</TD></TR><TR><TD CLASS="quote">As long as you know what your doing, its a piece of cake! </TD></TR></TABLE>
Old Jan 5, 2006 | 12:41 AM
littleredcivic's Avatar
possible to install and level in 2 hours. use the right tools and lube before touching fasteners, bolts will not break unless they are really rusted or seized.
Old Jan 5, 2006 | 01:54 AM
civic97dx's Avatar
Default Re: (littleredcivic)
I'm with you on the whole use the right tool and lube thing. And don't forget to use jackstands
Old Jan 5, 2006 | 03:02 AM
Chong's Avatar
ballin
Default Re: (civic97dx)
The bolts on the rear LCA are known to snap. But it all depends on the condition of you car.
Old Jan 5, 2006 | 03:52 AM
92vx-t's Avatar
Default Re: (Chong)
Yea the bolts on my rear LCA snapped on both sides, so a couple hours project turned into a three day project. But my car had 224,xxx miles on the body so that was kind of expected. But its a snap to install, shouldnt take no longer than a 2-3 hours.
Old Jan 5, 2006 | 10:53 AM
Is there a build on here somewhere for putting suspension on.
Old Jan 5, 2006 | 11:03 AM
Chong's Avatar
ballin
Default Re: (AllstockSIke)
http://www.c-speedracing.com/h...r.php
I know there are other DIY's somewhere around here, I can't seem to find them thou. This one is for an integra thou, but its pretty similiar.
Old Jan 5, 2006 | 11:05 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (Chong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllstockSIke &raquo;</TD></TR><TR><TD CLASS="quote">Is there a build on here somewhere for putting suspension on.</TD></TR></TABLE>
Here's the Koni shock install How-To. Same thing.
https://honda-tech.com/zerothread?id=1106020
Modified by litterbox at 3:15 PM 1/5/2006
Old Jan 5, 2006 | 11:06 AM
Chong's Avatar
ballin
Default Re: (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">
Here's the Koni shock install How-To. Same thing.</TD></TR></TABLE>
You forgot the link.
Old Jan 5, 2006 | 11:10 AM
Repins315's Avatar
Real easy. Just did mine on 99 ex model which is the same as yours, i believe. Just make sure to get an alignment afterwards. Also, you might need a camber kit that can cost up to 500 bucks to make tires wear evenly. GL!
Old Jan 5, 2006 | 11:15 AM
litterbox's Avatar
Default Re: (Chong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chong &raquo;</TD></TR><TR><TD CLASS="quote">
You forgot the link. </TD></TR></TABLE>
lol
Old Jan 5, 2006 | 11:18 AM
Im getting it from password. It comes with the camber kit. Thanks for the links ill check them out
Old Jan 5, 2006 | 11:21 AM
Turbo_y8's Avatar
Default Re: (Repins315)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Repins315 &raquo;</TD></TR><TR><TD CLASS="quote">Also, you might need a camber kit that can cost up to 500 bucks to make tires wear evenly. GL! </TD></TR></TABLE>
$500 for a camber kit, if you paid that, you must be in pain sitting from your ******* being raped!
130 for my omnipowered shipped
Old Jan 5, 2006 | 11:24 AM
Turbo_y8's Avatar
Default Re: (tuck'd98)
also, you can do you rear camber correction for about $5 the bolts that hold the upper control arm(UCA), go to a hardware store, find the same dia. and thread pitch bolt, slightly longer, 10-15 washers depending on hwo bad the camber is and place the washers between the uca and frame, gets to be tricky but worth the $5, and you can run aftermarket lca's which are shorter than stock so it brings the bottom of the tire toward the chassis
Old Jan 5, 2006 | 12:01 PM
boraVr's Avatar
i did mine in my garage. easy work, just nuts and bolts nothing to tech. but the hardest part was the bolts. snapped a few, went to honda to get replacements and the guy gave me some mopar like rust bust stuff. he calimed it was the best stuff out there. so i ussed it on all my other bolts before trying to bust em and it seemed to work well.
Old Jan 5, 2006 | 06:32 PM
92vx-t's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 &raquo;</TD></TR><TR><TD CLASS="quote">
Raped with no grease
Old Jan 5, 2006 | 07:25 PM
fms1day's Avatar
Love my Omni's... I didn't really have much of a problem putting them on.... Just make sure you preload them correctly. The only one problem that got me completely stumped is when I tried adjusting them... One of the coilovers adjuster wouldn't spin... I found out that it was dirty and the dirt was in the threads. So just clean them good if you ever find it hard to spin the bottom to adjust the height.
Old Jan 5, 2006 | 09:42 PM
Default Re: Omni suspension (fms1day)
the only rear camber kit that i know of that is close to 500 is the CUSCO rear upper adjustable control arm... but even that is only about 400...i know who makes it...don't pay for it...
Old Jan 5, 2006 | 09:48 PM
SHG_Beans's Avatar
make sure you use the height adjusters for height, and the preload adjusters for preload. some moron i got my omnis from used the preload to adjust ride height, and when the shocks were out of the car and unloaded the spring was loose! also make sure you take a ruler and match the ride height side to side so its even. It took me and a friend maybe two hours or less, that was after a bad case of the munchees and starting at 12am. Air tools work great, make sure you put pb blaster or some other rust penatrant (PB's my favorite) and let it soak. Good luck, cause once they're in your car will handle like its on rails!
Old Jan 6, 2006 | 01:27 PM
8krdline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic &raquo;</TD></TR><TR><TD CLASS="quote">possible to install and level in 2 hours.</TD></TR></TABLE>
Had my full suspension installed with camber kits and leveled in 2 hours.
Old Jan 6, 2006 | 11:40 PM
SHG_Beans's Avatar
wait by level you mean getting the car to finally sit level? measure it all before it goes on, its actually really easy to get it leveled first shot, saving a ton of time. we set it once, and that was that.
Old Jan 7, 2006 | 12:10 AM
D16z6BoostedEK's Avatar
took me only an hour for all four? anybody faster out there?
